  3. Crosstalk Analysis Error
  • Subscribers 21
  • Views 7352
Kang1985
Kang1985 over 4 years ago
I am trying to run crosstalk analysis through Allegro PCB designer, I got an error, it said "Failed to run the IDA analysis because the SPEEDEM generator executable could not be found. Ensure that Sigrity release 2021.1, ISR2(HF2) or later is installed and the SIGRITY_EDA_DIR environment variable is et to the installation directory." How can I solve this issue? my software version is Allegro 2021.
  • Master Shifu
    0 Master Shifu over 4 years ago
    Like message prompted you need to install the Sigrity tool and add above variable pointing to sigrity installation location. Also define an additional variable EAD_SIGRITY_DIR and set its value to sigrity installation location . eg  C:\Cadence\Sigrity2021.1
