  3. Moving Group of Text using skill
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 6830
vimaldevlpr
vimaldevlpr over 4 years ago
I want to move the group of highlighted text.  The destination location by user picking i don't know how to move by group please anyone help me out from this.
Tried by below method but it works only single text but i want in group of heighted texts
event = axlEnterEvent(list('PICK), nil, t)
event ->xySnap
 This three highlighted text simultaneously move together and want to place in user clicks location.
my code:
procedure(chk()
alist = '("A1" "A2" "A3")
axlClearSelSet()
axlSetFindFilter(?enabled '("NOALL", "TEXT"), ?onButtons "TEXT")
txtinp = axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
foreach(txtinp_loop txtinp
txtinp_val = txtinp_loop->text
foreach(HighList_loop alist
if(HighList_loop == txtinp_val then
axlHighlightObject(txtinp_loop)
  • mstaub
    0 mstaub over 4 years ago
    There isn't a clear way to do this using Skill, that I have come across at least. If you are purely looking to move text that requires the user to select the destination, you might just be better of using the move command in Allegro, and not using Skill. If for whatever reason you need to use Skill, your best bet would be to use the axlTransformObject() function, which is the closest thing you get to moving text like the 'move' command does.
    I wrote some test code to see if this works. This code makes the following assumptions:
    - The list of text values is predefined
    - The starting point of the move is the xy location of the first selected text object.
    Text version:
    axlCmdRegister("movetextgroup" 'MoveTextGroup)
    procedure(MoveTextGroup( )
    let( ((l_txt list())
    n_x
    n_y
    l_allText
    l_txtObjs
    n_startingPoint
    n_movePoint
    n_deltaMove
    l_txt = list("A1" "A2" "A3")
    ;Setup find filter and select all text in the design
    axlSetFindFilter(?enabled list("noall" "text") ?onButtons list("noall" "text"))
    l_allText = axlGetSelSet(axlAddSelectAll())
    ;Remove all text from the list but the ones we want to move. This is a quick and dirty way
    ; to do this, there is probably a more efficient way I just didn't have the time.
    l_txtObjs = setof(t_curTxt, l_allText, existss(s_t l_txt t_curTxt->text == s_t)!=nil)
    if(length(l_txtObjs) > 0 then
    ;Save the xy location of the first text element in the list
    n_startingPoint = car(l_txtObjs)->xy
    ;Prompt the user to select a destination point for the text
    n_movePoint = axlEnterPoint(?prompts list("Pick a location to move the text to.")) ; Ask user for point
    ;The axlTransformObject() function moves objects by design units and not to a specific xy location.
    ; Because of this we need to calculate what that xy delta is based on the origin of the first
    ; text object from our selection list (n_startingPoint) and the xy point the user selected.
    n_x = xCoord(n_movePoint) - xCoord(n_startingPoint)
    n_y = yCoord(n_movePoint) - yCoord(n_startingPoint)
    ;Form a coordinate variable
    n_deltaMove = n_x:n_y
    ;Move the text
    axlTransformObject(l_txtObjs, ?move n_deltaMove)
    axlClearSelSet()
    else
    println("ERROR: no objects selected to move")
    I couldn't find a way to upload the Skill file, so hopefully this helps.
