  3. SKILL FORM cell drop downs not working 17.4
  • Subscribers 19
  • Views 4545
HJerry
HJerry over 4 years ago
Hi all,
I have a GRID on a form that has cells that drop down. Some of the drop downs work fine, while others just flash.
I tested the Cadence form grid example and see the same issue. I am sure the example is old.
I started a ticket with support, but was wondering if anyone else has seen this issue and do you have a workaround.
Jerry
I did find, somewhat, of a work around. If  you delete the text in the cell, the drop down works.
This isn't a fix, but will work.
--Jerry
