  3. SKILL Object Trees
  • State Verified Answer
  • Subscribers 21
  • Views 6760
SKILL Object Trees
Biradin88
Biradin88 over 4 years ago
Which document I can use to check the children objects of parent objects for Allegro 17.4 SKILL programing? The same for parameters of objects. I want to see what I can access by using '->' on object.
For example MyText->text where MyText is a selected text returned from axlGetSelSet( ).
There should be something like object tree for any Symbol,Cline,Text,Shape etc..
Example:
MyText->text
MyText->textBlock
MyText->justify
  • mahimag
    mahimag over 4 years ago +1 verified
    you can find the list in the Allegro SKILL reference under section, " The Allegro PCB Editor Database User Model". I have beow link from Cadence Support website: https://support.cadence.com/apex/techpubDocViewerPage…
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1
    Look at the chapter 'The Allegro PCB Editor Database User Model' from Cadence Help or open $CDSROOT/doc/algroskill/o2dbdesc.html
  • mahimag
    +1 mahimag over 4 years ago
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=algroskill.xml&title=Allegro%20SKILL%20Reference%20--%20The%20Allegro%20PCB%20Editor%20Database%20User%20Model%20-%20Description%20of%20Database%20Objects&hash=pgfId-452619&c_version=17.4-2019&path=algroskill/algroskill17.4-2019/02dbdesc.html#pgfId-452619
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to DavidJHutchins
    Opps a typo, try 02dbdesc.html instead
