  3. SKILL program for creating shapes from closed polygon lines...
  • Subscribers 22
  • Views 9841
KAUSHAL S
KAUSHAL S over 4 years ago
I am working on composing shape from closed polygon lines ( Rectangle/ Square/ Circle/ Rounded corners polygon).
The Polygon lines are manually drawn in Allegro tool (*.dra  file)
Element type: Lines
Shape to be composed in Package Geometry-> Soldermask_Top
Problem I face is I'm able to get the dbid from all lines. but unable to compose the shape.  Could anyone help me to guide me in creating the SKILL
  • mstaub
    mstaub over 4 years ago in reply to ebecheto +1
    I actually just wrote a tool that does this exact thing. For 17.2 users this process is a littler more complex (similar to what ebecheto shows above). To summarize you will want to use a combination…
  • ebecheto
    ebecheto over 4 years ago
    Hi Kaushal,
    A long time ago, i played a little with Allegro skill. I can share an example of drawing a losange using axlDBCreateOpenShape and axlDBCreateCloseShape
    Maybe that will help you, maybe not. In any case; i cannot give support on that code since i do not use anymore allegro.
    procedure( losangeA(@optional (xy 0:0) (a 50) (d 0.2) (net "GND") (via t))
    (let (x y xy1) x=car(xy) y=cadr(xy)
    when(via (axlDBCreateVia "via" x+a/2:y+a*sqrt(3)/2 net))
    segments=(list
    xy1=x+d/sqrt(3):y+d
    x+2*a-d*sqrt(3):y+d
    x+a-d/sqrt(3):y+a*sqrt(3)-d
    x+d*sqrt(3)-a:y+a*sqrt(3)-d
    xy1)
    (setq shape (axlDBCreateOpenShape (axlPathStart segments) t "ETCH/TOP" net))
    (axlDBCreateCloseShape shape)))
    losangeA(8000:1000 5000 100 "GND_POWER" nil)
    procedure( losangeB(@optional (xy 0:0) (a 50) (d 0.2) (net "GND") (via t))
    (let (x y xy1)
    when(via (axlDBCreateVia "via" x+a/2:y-a*sqrt(3)/2 net))
    segments=(list
    xy1=x+d/sqrt(3):y-d
    x+2*a-d*sqrt(3):y-d
    x+a-d/sqrt(3):y-a*sqrt(3)+d
    x+d*sqrt(3)-a:y-a*sqrt(3)+d
    xy1)
    procedure( losangeC(@optional (xy 0:0) (a 50) (d 0.2) (net "GND") (via t))
    (let (x y xy1)
    when(via (axlDBCreateVia "via" x-a:y net))
    segments=(list
    xy1=x-2*d/sqrt(3):y
    x-a:y+a*sqrt(3)-2*d
    x-2*a+2*d/sqrt(3):y
    x-a:y+2*d-a*sqrt(3)
    xy1)
    ;printf("check segments:%L\n" segments)
    ;; ;losangeA()
    ;; ; losangeA(400:400 50 0.5 nil)
    ; losangeA(280:230 10 0.5 nil)
    ;; losangeB(280:230 10 0.5 nil)
    ;; losangeC(280:230 10 0.5 nil)
    procedure( trihexa(@optional (xy 280:230) (a 10) (d 0.2)(nets nil) (lays nil)(wirs nil)(siz nil))
    (let (x y)
    unless(nets nets='("Neta" "Netb" "Netc" ))
    unless(lays lays='("ETCH/SOUSTOP" "ETCH/SURBOTTOM" "ETCH/BOTTOM"))
    unless(wirs wirs='(0 0 0))
    unless(siz siz=0.2)
    losangeA(xy a d nth(0 nets))
    losangeB(xy a d nth(1 nets))
    losangeC(xy a d nth(2 nets))
    ; printf("wire:%L\n" wirs)
    wire=nth(0 wirs)(cond
    (wire==1 pts=list(x+a/2:y+a*sqrt(3)/2 x+2*a:y+2*a*sqrt(3)))
    (wire==2 pts=list(x+a/2:y+a*sqrt(3)/2 x-a:y-a*sqrt(3)))
    (wire==0 pts=list(x-2*a:y-2*a*sqrt(3) x+a:y+a*sqrt(3) ))(t pts='()))
    axlDBCreatePath(axlPathStart(pts siz) nth(0 lays) nth(0 nets))
    wire=nth(1 wirs)(cond
    (wire==1 pts=list(x+a/2:y-a*sqrt(3)/2 x+2*a:y-2*a*sqrt(3)))
    (wire==0 pts=list(x-2*a:y+2*a*sqrt(3) x+a:y-a*sqrt(3) ))(t pts='()))
    axlDBCreatePath(axlPathStart(pts siz) nth(1 lays) nth(1 nets))
    wire=nth(2 wirs)(cond
    (wire==1 pts=list(x-a:y x+4*a:y))
    (wire==2 pts=list(x-2*a:y x-a:y))
    (wire==0 pts=list(x-2*a:y x+4*a:y))(t pts='()))
    axlDBCreatePath(axlPathStart(pts siz) nth(2 lays) nth(2 nets))
    ;; trihexa(100:300 10 4)
    ;; trihexa(100:300 10 0 gnd bot)
    defun(add (a b) list(car(a)+car(b) cadr(a)+cadr(b)))
    ;add(xy1 xy2)
    defun( guidhexa (@optional (xy 200:200) (a 10) (d 3)(nets nil) (lays nil))
    unless(nets nets='("GND" "GND" "GND"))
    unless(d d=a/3)
    bot='("ETCH/BOTTOM" "ETCH/BOTTOM" "ETCH/BOTTOM")
    trihexa(xy a d )
    ;trihexa(xy a 0 nets bot)
    ;; --- hexagonal surrounding
    pts='() pt0=car(xy)+2*a:cadr(xy)
    for(i 0 6 pts=append(pts list(axlGeoRotatePt(i*60.0 pt0 xy))))
    axlDBCreatePath(axlPathStart(pts) car(lays) car(nets))
    axlDBCreateCircle((list xy 2*a))
    axlDBCreateCircle((list xy 2*d/sqrt(3)))
    xyc=add(xy 2*a:0)
    for(i 0 5 axlDBCreateCircle( (list axlGeoRotatePt(i*60.0 xyc xy) 2*d/sqrt(3))))
    xys=foreach(mapcar n '(-1 0 1) X=2*a+d*sqrt(3) Y=n*d list(X:Y X*(-1):Y))
    xyds=foreach(mapcar s xys list(add(xy car(s)) add(xy cadr(s))))
    for(i 0 2
    foreach( xyr xyds  ;xyr=car( xyds)
    lft=car(xyr) rgt=cadr(xyr)
    lftr=axlGeoRotatePt(i*60.0 lft xy)
    rgtr=axlGeoRotatePt(i*60.0 rgt xy)
    axlDBCreateLine(list(lftr rgtr))
    dold=d
    d=2*a*sqrt(3)
    axlDBCreateLine(list(add(xy 1.5*a:sqrt(3)*a/2) add(xy 1.5*a-sqrt(3)*d/2:sqrt(3)*a/2-d/2)) 0 "etch/blabla")
    d=dold
    guidhexa(450:300)
    ;; axlGeoRotatePt(60.0 pt0 xy)
    ;; x=60 y=60 a=10
    ;; xy=x:y
    ;; pts='()
    ;; pt0=x+2*a:y
    ;; for(i 0 6 pts=append(pts list(axlGeoRotatePt(i*60.0 pt0 xy))))
    ;; axlDBCreatePath(axlPathStart(pts) car(lays) car(nets))
    xy=450:200 pts='() a=10 pt0=car(xy)+2*a:cadr(xy)
    axlDBCreatePath(axlPathStart(pts))
    Hope it helps,
    • Vote Up -1 Vote Down
  • mstaub
    For 17.2 users this process is a littler more complex (similar to what ebecheto shows above). To summarize you will want to use a combination of the follow:
    Once you have the dbid/s of the line you will want to create a path object from the line segments (o_lineDbid->segments) using the path functions:
    axlPathStart()
    axlPathLine()
    axlPathArcRadius()
    and so on...
    Once you have this path object you can then use it to create a poly object using
    axlPolyFromDB()
    Note: this function returns a list and you will want to use the first element to create your shape (ie. myPoly = car(axlPolyFromDB(...)) )
    Finally we can use this poly object to create our shape using:
    axlDBCreateShape()
    or
    axlDBCreateOpenShape() and axlDBCreateCloseShape()
    Note: Both methods accept and r_path obect to define the boundary of the shape so you might even be able to skip creating the poly object. I haven't tried this to see how it works.
    Why is the 17.2 method more complex? Say you draw a rectangle but want to use that to create a shape with rounded corners. This will require you to go down a fun path of trig to modify your r_path object to change the segments and add arcs. I recently did this, and it might be what ebecheto is doing as well (I just haven't thoroughly looked at the code). This just complicates the code.
    Luckily all of this is simplified if you are using 17.4...
    For 17.4 this process has become a lot easier. There is a new Skill function that mimics that of Shape->Compose Shape.
    All you need to do is have the dbids of the line you draw and pass o_lineDbid->segments as the first argument in the function below and you shape is created!
    axlDBComposeShapesFromLines(
    o_dbid/lo_dbids
    n_maxGap
    n_cornerRadius
    t_layer
    b_shapeFill
    [t_netName]
    [b_deleteLines]
    ⇒ o_dbid/lo_dbids/error string
    o_dbid/lo_dbids
    Any combination of line segments, lines, and shapes in the database for conversion. The shapes may become voids in other shapes, and so on, based on the nesting of the resulting shapes that are created.
    n_maxGap
    The maximum air gap between vertices, which should be close enough to create a closed shape outline. This argument corresponds to the Maximum gap option of the compose shape command. If nil, the value is computed from the provided segments.
    n_cornerRadius
    Radius for corners, if corners are to be rounded. This argument corresponds to the Radius option of the compose shape command. If nil, corners are not rounded.
    t_layer
    Destination layer on which shape is to be created
    b_shapeFill
    Either t or nil:
    • t: creates a solid-filled shape
    • nil: creates an unfilled shape
    Certain layers are allowed to have only one type of shape. If the specified destination layer only allows one shape fill state, this argument is ignored, and the layer's required shape type is used.
    [t_netName]
    Net assigned to the shape. Only applicable when creating shapes on cross-section layers.
    [b_deleteLines]
    t/nil indicates whether the lines used in the construction of the shapes should be deleted. Lines not incorporated into a shape are never deleted.
    Like I said, I literally just did this using both the 17.2 and 17.4 implementations. Let me know if you need any additional help.
