  3. SKILL program to save user colors
  • State Suggested Answer
  • Replies 9
  • Answers 1
  • Subscribers 22
  • Views 11696
soll
soll over 4 years ago
Hello :)
I have written a SKILL program that save/load the colors of a BRD. It saves both the color palette and the colors associated with each subclass into a file, that can be loaded to another BRD (or the same).
It mostly works :p On some (rather) rare occasions, the SaveColors() function will skip some subclasses, or mess their name, and I have no idea why. But most of the time, it works. It has been written with Cadence 17.2, but should work on any version.
Sometime, after loading a color file, I get this error (SPMHDB-197): Subclass color index out of range. If anybody know what it exactly means, I am interested. If someone know were I could find a list of all the error codes and their meanings, I would be very interested too !
If you have any idea on how to make this program better or if you spot some grammatical/spelling mistakes, don't hesitate to tell !
If someone knows how to save the global transparency and shapes transparency of the Display tab (color dialog window), I think it would be a nice addition.
REMINDER : always double save you BRD before executing some SKILL code from and internet stranger :p I didn't had any problem with this program, but I don't know if it works the same on my setup and on yours. It probably does.
Here is the code :
; SaveColors() : save subclasses colors in a .colors file
; LoadColors() : load subclasses colors from a file
; skill "load SaveColors.il"
axlCmdRegister("savecolors" 'SaveColors ?cmdType "general")
axlCmdRegister("loadcolors" 'LoadColors ?cmdType "general")
procedure( SaveColors()
let((colorFileName colorFilePort subclass)
    ; color file creation
    colorFileName = axlDMFileBrowse(nil t ?defaultName strcat("./" axlCurrentDesign() "-" getLogin() ".colors") ?title "Save Colors As")
    colorFilePort = outfile(colorFileName)
    fprintf(colorFilePort ";:;:;:;:;:;:;:;:;:;:;:;:;:;:;:\n\n")
    fprintf(colorFilePort "    Color file       : %s\n" colorFileName)
    fprintf(colorFilePort "    User             : %s\n" getLogin())
    fprintf(colorFilePort "    Drawing          : %s.brd\n" axlCurrentDesign())
    fprintf(colorFilePort "    Software version : %s\n" getVersion())
    fprintf(colorFilePort "    Date/Time        : %s\n\n" getCurrentTime())
    fprintf(colorFilePort "---\n")
    ; get color palette
    paletteList = axlColorGet('all)
    foreach(color paletteList
        fprintf(colorFilePort "%d~%d~%d\n" nth(0 color) nth(1 color) nth(2 color))
    ) ;foreach
    fprintf(colorFilePort "???\n")
    ; get colors for each subclass
    foreach(ClassName axlGetParam("paramLayerGroup")->groupMembers
        foreach(SubclassName (axlGetParam(strcat("paramLayerGroup:" ClassName))->groupMembers)
            subclass = axlLayerGet(strcat(ClassName "/" SubclassName))
            fprintf(colorFilePort "%s/%s~%d~%d\n" ClassName SubclassName subclass->color subclass->pattern)
        ) ;foreach
    ) ;foreach
    fprintf(colorFilePort "!!!\n")
    close(colorFilePort)
    printf("Colors saved under %s." colorFileName)
)) ;let,procedure
procedure( LoadColors()
prog((colorFileName colorFilePort currentLine parsedLine colorPalette)
    colorFileName = axlDMFileBrowse(nil nil ?title "Load Colors")
    colorFilePort = infile(colorFileName)
    currentLine = ""
    ; checks that the selected file is a color file
    if(gets(currentLine colorFilePort) != ";:;:;:;:;:;:;:;:;:;:;:;:;:;:;:\n"
        then
            ;println(currentLine)
            axlUIConfirm("Le fichier choisi n'est pas compatible\n" 'error)
            return()
    ) ;if
    ; get to the color list
    while(currentLine != "---\n"
    ) ;while
    ; set the colors palette
    while(currentLine != "???\n"
        unless( currentLine == "???\n"
            parsedLine = parseString(currentLine "~")
            parsedLine = list(atoi(nth(0 parsedLine)), atoi(nth(1 parsedLine)), atoi(nth(2 parsedLine)))
            colorPalette = cons(parsedLine colorPalette)
        ) ;unless
    ) ;while
    colorPalette = reverse(colorPalette)
    axlColorSet('all colorPalette)
    ; set the subclasses colors
    while(currentLine != "!!!\n"
        subclass = axlLayerGet(nth(0 parsedLine))
        if(subclass != nil
            then
                subclass->color = atoi(nth(1 parsedLine))
                subclass->pattern = atoi(nth(2 parsedLine))
                axlLayerSet(subclass)
        ) ;if
    ) ;while
    ; update display
    axlVisibleUpdate(t)
    printf("Color file loaded succesfully (I guess).")
)) ;let,procedure
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 suggested
    attached is some skill code I wrote ~20 ago, I haven't heard of any issues with it recently... procedure((XXX_write_colors \@optional FileName) prog((fptr OutputName Classes Class SubClasses Layer lineCnt…
  • soll
    soll over 4 years ago +1
    I just realized, looking at the "related topics" on the right that there is a function to do this built in Allegro... File > Export > Parameters... Well that was fun anyway.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    prog((fptr OutputName Classes Class SubClasses Layer lineCnt visible)
    if( FileName then
    (OutputName = strcat(simplifyFilename(".") "/" FileName))
    (OutputName = FileName)
    else
    (OutputName = "colors.alc")
    (OutputName = strcat(simplifyFilename(".") "/colors.alc"))
    (lineCnt = 0)
    (visible = 0)
    if(( stringp(OutputName) && (isFile(OutputName) == t)) then
    unless(deleteFile(OutputName)
    (axlMsgPut "ERROR: could not remove existing file %s" OutputName)
    return()
    if((fptr = outfile(OutputName)) then
    (Classes = ((axlGetParam "paramLayerGroup")->groupMembers))
    (axlMsgPut "building class/subclass layer list.")
    (Layer = nil)
    foreach(class Classes
    (Class = (axlGetParam sprintf(nil "paramLayerGroup:%s" class)))
    (SubClasses = Class->groupMembers)
    foreach(SubClass SubClasses
    (Layer = (axlGetParam sprintf(nil "paramLayerGroup:%s/paramLayer:%s" class SubClass)))
    if((Layer->visible) then
    (visible = 1)
    else
    (visible = 0)
    fprintf(fptr "%s/%s/%d/%d\n" class SubClass (Layer->color) visible)
    lineCnt++
    ;; phase 2 - write net colors to file...
    foreach(net ((axlDBGetDesign)->nets)
    when(axlIsCustomColored(net)
    fprintf(fptr "(axlCustomColorObject %s %d)\n" net->name axlIsCustomColored(net))
    close(fptr)
    (axlMsgPut "%d layers written to %s" lineCnt OutputName)
    else
    (axlMsgPut "ERROR: could not open output file %s" OutputName)
    return()
    procedure((XXX_read_colors \@optional (FileName "colors.alc"))
    ;;"read the Allegro Layer Colors ( alc ) file & set the layer attributes"
    prog((inport lineCnt setCnt addCnt netCnt DataLine
    TempLine DataList Class SubClass Layer Net TextString color visible)
    if(( stringp(FileName) && (isFile(FileName) == t)) then
    (inport = infile(FileName))
    (lineCnt = 0)
    (setCnt = 0)
    (addCnt = 0)
    (netCnt = 0)
    when(inport
    while(gets(DataLine inport)
    lineCnt++
    (TempLine = parseString(DataLine "\n\r"))
    if(nindex(car(TempLine) "(axlCustomColorObject") then
    (SubClass = nil)
    (DataList = parseString(car(TempLine)))
    axlClearSelSet()
    (Net = axlDBFindByName('net cadr(DataList)))
    when(Net
    (axlCustomColorObject Net atoi(caddr(DataList)))
    (netCnt++)
    axlClearSelSet()
    else
    (DataList = parseString(car(TempLine) '\/))
    if((length(DataList) > 0) then
    if(stringp(car(DataList)) then
    (Class = car(DataList))
    else
    (Class = "ETCH")
    if(stringp(cadr(DataList)) then
    (SubClass = cadr(DataList))
    if(stringp(caddr(DataList)) then
    (color = atoi(caddr(DataList)))
    else
    (color = 0)
    if(stringp(cadddr(DataList)) then
    (visible = atoi(cadddr(DataList)))
    else
    (visible = 0)
    when(SubClass
    (Layer = (axlGetParam sprintf(TextString "paramLayerGroup:%s/paramLayer:%s" Class SubClass)))
    if((!Layer && !(Class == "ETCH") && !(Class == "ANTI ETCH") && !(Class == "PIN") && !(Class == "VIA CLASS") && !(Class == "DRC ERROR CLASS") && !(Class == "ROUTE KEEPOUT") && !(Class == "VIA KEEPOUT")) then
    addCnt++
    (axlLayerCreateNonConductor sprintf(TextString "%s/%s" Class SubClass))
    if(Layer then
    setCnt++
    (Layer->color = color)
    if((visible == 1) then
    (Layer->visible = t)
    else
    (Layer->visible = nil)
    (axlSetParam Layer)
    close(inport)
    (axlMsgPut "%d lines processed, %d layers set, %d layers added,%d nets set" lineCnt setCnt addCnt netCnt)
    (axlUIWRedraw nil)
    procedure(XXX_export_colors_Callback(form)
    ;;"process the user input"
    let(()
    case((form->curField)
    ("execute"
    axlFormClose( form)
    axlCancelEnterFun()
    if(( stringp(XXX_FormFile) && (isFile(XXX_FormFile) == t)) then
    deleteFile(XXX_FormFile)
    XXX_write_colors( XXX_IO_FileName )
    t
    ("cancel"
    axlFormClose( form)
    axlCancelEnterFun()
    nil
    ("filename"
    (XXX_IO_FileName = (form->curValue))
    t
    procedure(XXX_export_colors_BuildForm( XXX_FormFileArg )
    ;;"build the form file"
    let((FORMFILE)
    if(( stringp(XXX_FormFileArg) && (isFile(XXX_FormFileArg) == t)) then
    deleteFile(XXX_FormFileArg)
    (FORMFILE = outfile(XXX_FormFileArg))
    fprintf(FORMFILE "FILE_TYPE=FORM_DEFN VERSION=2\n")
    fprintf(FORMFILE "FORM\n")
    fprintf(FORMFILE "FIXED\n")
    fprintf(FORMFILE "PORT 50 10\n")
    fprintf(FORMFILE "HEADER \"Layer Colors\"\n")
    fprintf(FORMFILE "\n")
    fprintf(FORMFILE "TILE\n")
    fprintf(FORMFILE "TEXT \"Output File: ( recommend a file extension .alc )\"\n")
    fprintf(FORMFILE "TLOC 1 1\n")
    fprintf(FORMFILE "ENDTEXT\n")
    fprintf(FORMFILE "FIELD filename\n")
    fprintf(FORMFILE "FLOC 1 4\n")
    fprintf(FORMFILE "STRFILLIN 21 128\n")
    fprintf(FORMFILE "ENDFIELD \n")
    fprintf(FORMFILE "FIELD execute\n")
    fprintf(FORMFILE "FLOC 1 15\n")
    fprintf(FORMFILE "MENUBUTTON \"Run\" 11 3\n")
    fprintf(FORMFILE "ENDFIELD\n")
    fprintf(FORMFILE "FIELD cancel\n")
    fprintf(FORMFILE "FLOC 27 15\n")
    fprintf(FORMFILE "MENUBUTTON \"Cancel\" 11 3\n")
    fprintf(FORMFILE "ENDTILE\n")
    fprintf(FORMFILE "ENDFORM\n")
    close(FORMFILE)
    procedure(XXX_export_colors()
    ;;"main routine for export_colors"
    let((fileList form)
    (XXX_IO_FileName = "")
    (XXX_FormFile = strcat(makeTempFileName(strcat(XXX_TmpDir "Form")) ".form"))
    XXX_export_colors_BuildForm(XXX_FormFile)
    (fileList = setof(x getDirFiles("./") rexMatchp(".alc$" x)))
    (form = axlFormCreate( gensym() XXX_FormFile '(e outer) 'XXX_export_colors_Callback t))
    axlFormTitle( form "Export Colors")
    axlFormSetField( form "view_file" car(fileList))
    foreach(fileName fileList
    axlFormSetField( form "file_list" fileName)
    axlFormDisplay( form)
    procedure(XXX_import_colors()
    ;;"allow user to browse for allegro layer colors ( alc ) file"
    prog((FileName)
    (FileName = axlDMFileBrowse( nil nil ?optFilters " files(*.alc)|*.alc|"))
    XXX_read_colors(FileName)
    axlCmdRegister( "write_colors" 'XXX_write_colors)
    axlCmdRegister( "export_colors" 'XXX_export_colors)
    axlCmdRegister( "read_colors" 'XXX_read_colors)
    axlCmdRegister( "import_colors" 'XXX_import_colors)
  • soll
    0 soll over 4 years ago in reply to DavidJHutchins
    Thank you for the input! It is good too know that well written SKILL code still works fine after 20 years.
  • soll
  • zpofrp
    0 zpofrp 9 months ago in reply to DavidJHutchins
    *Error* eval: unbound variable - XXX_TmpDir
    i add a code "(XXX_TmpDir = getWorkingDir())"after"procedure(XXX_export_colors()
    let((fileList form)"
  • Hoangkhoipcb
    0 Hoangkhoipcb 9 months ago in reply to zpofrp
    Hi zpofrp!
    You should add code like this.
    BR.
    HoangKhoi
