  3. How to get the physical cset of a net using SKILL
  • Subscribers 21
  • Views 8035
soll
soll over 4 years ago
Hello !
I am trying to get the physical cset assigned to a net using SKILL.
I tried using this : net->prop->PHYSICAL_CONSTRAINT_SET
Unfortunately, if the net doesn't have a physical cset assigned (it is using DEFAULT) or if the cset is assigned to a class that contain the net, the property isn't added to the net.
So the only nets which have this property are the nets that have a cset directly assigned (basically 0 in most of my designs).
I have gone through the axlCNS functions but didn't found a match.
Does anyone have an idea on how to do this ? Thank you very much !
  • mahimag
    0 mahimag over 4 years ago
    Spacing_Constraint_Set and Physical_Constraint_Set are properties that get assigned when CSet is referenced on any net. we can extract and disply this property,
    Try following lines of SKILL:
    axlClearSelSet()
    axlSetFindFilter(?enabled '("noall" "nets"))
    axlSingleSelectName("NET" "A0")
    myprops = axlDBGetProperties(car(axlGetSelSet()) '("user" "allegro")
    BGA_SPACE is the CSET, output value stored in myprops:
    ((LOGICAL_PATH "@demo_m.root(sch_1):a0")
    (SPACING_CONSTRAINT_SET "BGA_SPACE")
  • soll
    0 soll over 4 years ago in reply to mahimag
    Hello and thank you for the reply. The problem is that the property doesn't exist on the nets if the constraint set is assigned to a class to which the net belong... I just tried, using axlDBGetProperties() and I don't get the cset either, I only get the LOGICAL_PATH.
  • soll
    It appears that the PHYSICAL_CONSTRAINT_SET property, when not assigned directly to the net, is assigned to one of it's parentGroups. So I have been searching how to use these parentGroups and have came up with strange results.
    I have used this test program :
    axlClearSelSet()
    axlSetFindFilter(?enabled '("noall" "nets") ?onButtons '("noall" "nets"))
    axlSelect()
    NET = car(axlGetSelSet())
    print("net : ")
    println(NET->name)
    print("Physical CSet assigned : ")
    println(NET->prop->PHYSICAL_CONSTRAINT_SET)
    PARENTS = NET->parentGroups
    print("parent groups : ")
    println(PARENTS)
    print("parent groups properties : ")
    println(axlDBGetProperties(PARENTS '("user" "allegro")))
    axlClearSelSet()
    axlFinishEnterFun()
    I try two different nets. The first returns :
    "net : ""JTAG_VREF_3V3"
    "Physical CSet assigned : "nil
    "parent groups : "nil
    "parent groups properties : "((AUW_LIB_VERSION "16.6") (AUW_BOARD_TECH "ve010") (AUW_BOARD_CLASS "b") (PHYSICAL_CONSTRAINT_SET "DEFAULT") (SPACING_CONSTRAINT_SET "DEFAULT") the list continues with all the properties attaches to the parent groups
    The second net returns :
    "net : ""IRRX_CH3_TEST"
    "parent groups : "(dbid:00000218E2FD8848)
    "parent groups properties : "nil
    *WARNING* (axlDBGetProperties): Invalid database id argument - (dbid:00000218E2FD8848)
    So the first net parentGroups is nil, but the parentGroups properties exists, the second net does have a parentGroups attribute, but the prop list is nil. I get the warning because I give a list to axlDBGetProperties. Problem is, if I use a foreach to access each item of the list, it prints nothing...
    Does anyone could explain theses results ? Thank you very much !!
