  3. funckey to a skill program
  • State Verified Answer
  • Subscribers 21
  • Views 8005
SOT23
SOT23 over 4 years ago
Hello !
I have written some skill programs that I load at Allegro's startup using the allegro.ilinit file.
I have some funckeys that I have programmed in my env file.
I would like to program some of my skill functions as funckeys, but I couldn't manage to do that. Does the env file load before the allegro.ilinit ? Does the "axlCmdRegister()" function names I have entered can be used in the env file ?
Thank you !
  • mahimag
    mahimag over 4 years ago +1 verified
    yes, you can use axlcmdregister commands in your funckey. To do so you need to add <load "filename.il"> line in allegro.ilinit in your pcbenv folder. add <funckey m command_name> in your env file. Now…
  • DavidJHutchins
    DavidJHutchins over 4 years ago in reply to mahimag +1
    I have found that you don't really need to register the skill code as a command to run it, for example I have the following alias defined in my env file: alias vnp ((axlVisibleLayer "package geometry…
  • mahimag
    +1 mahimag over 4 years ago
    Now invoke allegro and you could use m to run the axlcmdregister command because your skill file is loaded at hte time of startup.
    I tried this at my end and it is working fine.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to mahimag
    alias vnp ((axlVisibleLayer "package geometry" nil)(axlVisibleLayer "PACKAGE KEEPIN" nil)(axlVisibleLayer "PACKAGE KEEPOUT" nil)(axlVisibleUpdate t))
    after typing in vnp<enter> at the Command> prompt  the journal file shows the following:
    \i (00:07:38) skill '(axlVisibleLayer "package geometry" nil)(axlVisibleLayer "PACKAGE KEEPIN" nil)(axlVisibleLayer "PACKAGE KEEPOUT" nil)(axlVisibleUpdate t)'
  • SOT23
    0 SOT23 over 4 years ago in reply to mahimag
    Hello and thank you very much !
    I removed everything and tried again and it works. It seems my custom menu was screwing things up.
  • SOT23
    0 SOT23 over 4 years ago in reply to DavidJHutchins
    This is very interesting !
    I couldn't manage to make the skill work :p it says unbound variable PACKAGE), but the .jrl file does show that the parenthesis were interpreted as skill code. Maybe I will try to convert my smaller programs to aliases.
