  3. How to format outfile with ansi font by skill
  • Subscribers 23
  • Views 5268
luanvn81
luanvn81 over 4 years ago
Hi everyone!
 As the subject, I want to create an text file with format ansi font by using command outfile("./test.txt" "w").  How can I do that? Please help me.
Thanks alot
Luan.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    I don't think this can be done since plain text files don't store font information, unless you have a custom file format that you're not noting in the question. Changing the text in Windows NotePad is simply a display feature and doesn't do anything to the file itself
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to DavidJHutchins
    What is the standard font style used in PCB editor ?
  • Noradavis
    0 Noradavis over 4 years ago in reply to Schulz Jordan
     the output from Wmic through more : wmic CPU Get AddressWidth |more >> "C:\test.txt". Edit for some more background: the issue you see ... Methods provided by this module · Clicker counter   1) fonstyle.apply(): This method adds formatting to the entire input argument string. ·You'll learn about Python's string format method and the formatted string ... braces is literal text that's copied directly from the template to the output.The format() method is used to perform a string formatting operation. The string on which this method is called can contain literal text or ...
