  3. tip - here's how to reduce Allegro board file size
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 6688
avant
avant over 4 years ago
You can reduce the board extents to reduce the board file size.
I turn all layers on and measure the X dimension to include everything that is visible, and then set the drawing extents to this measurement.
Apparently, unused space in the board file increases the file size.
I'm working on a customer board file and was able to reduce the board file size by 100MB.
Just wanted to pass along this tip.
  • Wild
    Wild over 4 years ago in reply to avant +2 suggested
    The file date stamp on my pc is from 2010. So Ron Guthrie, I say Thanks! /******************************************************************* * DISCLAIMER: The following code is provided for Cadence…
  • Wild
    0 Wild over 4 years ago
    There is a skill code out there called auto size.  much easier.
  • avant
    0 avant over 4 years ago in reply to Wild
    Out where? This would come in handy!
  • Wild
    0 Wild over 4 years ago in reply to avant
    * DISCLAIMER: The following code is provided for Cadence customers *
    * to use at their own risk. The code may require modification to   *
    * satisfy the requirements of any user. The code and any           *
    * modifications to the code may not be compatible with current or  *
    * future versions of Cadence products.                             *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING   *
    * WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES  *
    * OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.              *
    ; File: autosize.il
    ; Usage: Load this file autosize.il
    ;  Issue the command autosize on the Allegro command line.
    ;    Optionally you can specify an amount to expand the drawing extents
    ;    If you wish to make the drawing size 200 units larger in all directions
    ;    than the extents of the drawing you would enter
    ;    autosize 200
    ;    The expand option is optional and if it is not specified then the
    ;    drawing will be resized to the extents of the current database objects.
    ; Note:
    ;    THIS CODE IS UNSUPPORTED AND HAS HAD MINIMAL TESTING.
    ;    This example from the online documentation is intended to
    ;    show the use of the axlExtentDB and axlDBChangeDesignExtent
    ;    functions to resize a drawing based on the database objects.
    ;Author: Ron Guthrie
    ; Cadence Design Systems
    ; Version 1.0
    ; Date: August 31,2006
    axlCmdRegister("autosize" 'RBG_autosize)
    procedure( RBG_autosize(@optional (expand "0"))
    let( list(extents ll_exp oversize)
        oversize=evalstring(expand)
        extents = axlExtentDB('obstacle)
        ll_exp=minus(oversize)
        extents = bBoxAdd(extents list( ll_exp:ll_exp oversize:oversize ))
        unless(axlDBChangeDesignExtents(extents)
            axlMsgPut(list("Failed to resize drawing.\n" 3))
        );endif
    );endlet
    );endproc
    • Vote Up +2 Vote Down
  • avant
    Thanks!
  • Wild
    BTW - I still am on 16.6, and have not tried it on 17.x, Note sometimes there is an issue with large boards with D or larger fabrication boarders, when I save the board after using the code Allegro will create an unrecoverable error, and save the database as a .sav file.  This is easily fixed by hand, I just increase the boundaries a little.  It happened maybe 1 out of 100 or so boards.  I find it extremely useful, especially when I get designs from other people or organization/companies.  I just wish I could find skill code to remove customized sub classes, which I find in almost every design from someone else
