  3. Dehighlight symbols using skill and Dehighlight symbols...
  • Subscribers 21
  • Views 5275
Dehighlight symbols using skill and Dehighlight symbols use command
WangL95
WangL95 over 4 years ago
Hi All,
I am in learning process and have a problem with using skill to dehighlight highlighted symbols in layout.
I used highlight command "Display->Highlight" to highlight several symbols. Then use skill below to try dehighlight them but it has not success.
Can someone help me for this?
Thank you so much!
axlCmdRegister( "dh" 'dehighlight)
procedure( dehighlight()
symbols_list = nil
axlClearSelSet()
axlSetFindFilter( ?enabled (list "symbols" ) ?onButtons (list "symbols"))
;axlSetFindFilter( ?enabled '(noall symbols) ?onButtons '(noall symbols))
db_item = axlGetSelSet(axlAddSelectAll())
foreach(item db_item
if( axlIsHighlighted(item)
then
symbols_list = cons(item symbols_list)
axlClearSelSet()
axlDehighlightObject(symbols_list)
  • Uri Chaplin
    Uri Chaplin over 4 years ago
    this function have 2 parameters
     axlDehighlightObject( [lo_dbid] [g_permHighlight] ) ⇒ t/nil
    try to use axlDehighlightObject(symbols_list t)
    BTW no need create list, do it inside foreach
      if( axlIsHighlighted(item) then  axlDehighlightObject(item t) )
  • WangL95
    WangL95 over 4 years ago in reply to Uri Chaplin
    Thank you so much!
