  3. Extracting Board Shape via Skill / get radius / angle of...
  • Subscribers 20
  • Views 4647
Extracting Board Shape via Skill / get radius / angle of arc segments
Juuls
Juuls over 3 years ago
I need to extract the board shape, so that I can rebuild it with lines, arcs etc.
What I do is:
dsn = axlDBGetDesign()
outline = dsn->designOutline
segments = outline->segments
If a segment has the objType "line", there is a start point and end point ... ok so far, but if the objType is "arc", there is also just a start point and end point, but I need the radius, the start angle and the end angle.
Maybe it can be calculated from the bBox, but I would be suprised, if that's preferred solution ... anyway, I wouldn't know how ...
Can anyone help me, what is the correct way to get the needed information about the arc segments?
Thank you for your help in advance!
Best regards,
Julian
  • Juuls
    0 Juuls over 3 years ago
    Okay,
    never mind ... I don't know, what I did before, but my arc segment returns all necessary informations ...
    objType isCircle isClockwise isEtch parent
        net startEnd radius width xy
        bBox readOnly layer font prop
