  3. Playing a movie from a SKILL form
  • Replies 7
  • Subscribers 23
  • Views 6572
David M Gonzales
David M Gonzales over 3 years ago
Is there a skill command that could play a recorded movie (.mov file)?
  • DE202408202727
    0 DE202408202727 over 3 years ago
    The simplest way is to just use axlHttp.
    eg axlHttp("c:/temp/myMovie.mov")
  • David M Gonzales
    0 David M Gonzales over 3 years ago
    Thanks eDave! Yes, I am able to play the movie when I link to the file on my local drive. However, when I try to access the file on our network library drive, it fails. Could it be because the network folder name contains spaces?
  • DE202408202727
    0 DE202408202727 over 3 years ago in reply to David M Gonzales
    Possibly. What does your command look like?
  • David M Gonzales
    0 David M Gonzales over 3 years ago in reply to DE202408202727
    axlHttp( "W:/Shared With Me/Libraries/How-To-Videos_and_Guides/UsingStackup&Constraint_Skill_Command.mov" )
  • David M Gonzales
    0 David M Gonzales over 3 years ago in reply to David M Gonzales
    I suppose I could copy the file locally to a predictable folder, play the movie, and delete it at the end. Unless anybody has a better solution?
