  3. Compare 2 padstacks using SKILL
  • Subscribers 21
  • Views 4521
fithawi
fithawi over 3 years ago
How to compare 2 padstacks using SKILL?
  • Kirti Sikri
    0 Kirti Sikri over 3 years ago
    A padstack is a collection of information that is associated with a pin or a via, used to model different types of pads
    A padstack is a file that contains the following information for each layer: • Pad size and shape • Drill size and drill display figure • Mask layers such as Soldermask, Pastemask, and Filmmask
    axlLoadPadstack loads a padstack by attempting to find the padstack by name in the existing database. Failing that, Allegro PCB Editor looks in the pad library on the disk. padStackId=axlLoadPadstack("60C85C35D")
    If it finds the padstack, padStackId will not be NULL. If you print information about the padstack using padStackId->??, you will get the information about drill, layers span, and the list of pads, as shown in the image
  • Kirti Sikri
    There are 18 pads in this padstack (the number of elements in the pad list), and information about some of the pads is shown in the image below
    Total Number of pads = 3* Number of Layers + Soldermask_top + Soldermask_bottom + pastemask_top + pastemask_bottom + filmmask_top + filmmask_bottom
    Number of Layers are 4 (TOP, GND, VCC, and BOTTOM) =3 *4 + 6=18
    Note that for every layer, three types of pads are defined: Regular, Thermal, and AntiPad. You can confirm it from the Padstack Editor Design Layers
    For the maskLayers, the information about the pad from Allegro SKILL and Padstack Editor is shown in the image below:
  • Kirti Sikri
    For more details you can checkout the article On COS here
