  3. There is a BUG in the skill command axlGetParam("artwork...
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 2478
There is a BUG in the skill command axlGetParam("artwork:VCC")?? Solve it.
aarom
aarom over 3 years ago
p = axlGetParam("artwork") is to find all the Films under the artwork (all have the name of the Films layer).
p->??
r = axlGetParam("artwork:VCC") is the specified layer, find the Film VCC under artwork. (detailed setting data of the output layer).
r->??     Same as    r->groupMembers
There is a BUG. If the VCC layer is not built, it will automatically return to axlGetParam("artwork"), and you will never be able to find out whether you have built the layer........It will not be nil.
Check the information to learn...
axlGetParam("artwork") does not have r->name function, it will be nil
axlGetParam("artwork:VCC") has r->name function, which will display layer name. Will t / nil.
Please use "axlGetParam("artwork:VCC") ->name" to judge and process.
  • Ejlersen
    Ejlersen over 3 years ago +1 suggested
    Hi If you need to hardcode a name like VCC, then why not first check if it is a groupMember, if that check returns nil there is no reason to run the command. memv("VCC" axlGetParam("artwork")->groupMembers…
  • mahimag
    0 mahimag over 3 years ago
    For any bug fixes in the software, you can report to Cadence Support through support.cadence.com
  • Ejlersen
    0 Ejlersen over 3 years ago
    Hi
    memv("VCC" axlGetParam("artwork")->groupMembers)
    Best regards
    Ole
