  3. Skill code not loading correctly at startup
  • State Verified Answer
  • Subscribers 20
  • Views 4542
leto
leto over 3 years ago
Hello All,
I'm using this code in "allegro.ilinit" to load all my skill files in skill folder when Allegro PCB starts
setSkillPath(buildString(cons("c:/SPB_Data/pcbenv/skill" getSkillPath())))
foreach(dir getSkillPath()
    when(isDir(dir)
        foreach(file rexMatchList("\\.il$" getDirFiles(dir))
             when(
                 printf("Loading Skill file: %s\n" file)
                 load(file)
However the code seem to be only partially loaded and some functions within the code not running at all
only by retyping    load("myskillscript.il")   does the code loads fully
Alternately i can specifically load each skill code by name in the allegro.ilinit file by adding this line for each skill script
but that makes the code less portable.
Thanks All
  • DE202408202727
    DE202408202727 over 3 years ago +1 verified
    That code looks like it should work if none of your scripts have errors - although I don't see the need for either of the two "when" statements. Loading all of your Skill utilities is overkill. I prefer…
  • DE202408202727
    +1 DE202408202727 over 3 years ago
    Loading all of your Skill utilities is overkill. I prefer to use the autoload feature:
    myskillStart.autoload = "myskillscript.il"
  • leto
    0 leto over 3 years ago in reply to DE202408202727
    Thank You Dave!!
