  3. Net Resistance By Skill
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 4164
smah
smah over 3 years ago
Hi All,
We can check Resistance of all Nets by creating a report from Tools.
Tools->Reports->New/Edit: Select database view ->NET and Available Fields -> NET_RESISTANCE
Kindly let me know if there is a way to generate this report of extracting resistance of all nets through SKILL code?
Regards.
  • mahimag
    mahimag over 3 years ago +1 suggested
    you can try axlExtractToFile() skill API to e xtracts data from the current design into an ASCII file. Below are the arguments required for the API.
  • mahimag
    0 mahimag over 3 years ago
    you can try  axlExtractToFile() skill API to extracts data from the current design into an ASCII file. Below are the arguments required for the API.
