  3. What Is Returned from dbid->pins->startEnd
  • State Verified Answer
  • Subscribers 22
  • Views 2942
MarkGorecki
MarkGorecki over 3 years ago
My code:
symDbidList = setof(symDbid axlDBGetDesign()->symbols symDbid->component->class == "DISCRETE")
;For each symbol dbid in the list, get X, Y,ref des, rotation, and comp name
smdOutput = outfile("./POD_SMD_Table.txt" "w")
foreach( symDbid symDbidList
symLoc = symDbid->xy
symLocX = car(symLoc)
symLocY = cadr(symLoc)
symRefDes = symDbid->refdes
symRot = symDbid->rotation
symName = symDbid->name
pinObj = (car (symDbid->pins))
pinLayer = pinObj->startEnd
pinLayer = ("CONDUCTOR/L06" "CONDUCTOR/L06")
I used:
layTxt1 = ( nthelem 1 pinLayer) which gave me "CONDUCTOR/L06"
I want to get the "L06" part of what looks like a string, but parsing using "/" doesn't work, and neither does substring.
Can someone please tell me how to get the "L06" portion from layTxt1?
  • JuanCR
    JuanCR over 3 years ago +2 verified
    Since pinLayer is a string, you can use the following command to get the "L06" substring from it: strpbrk( pinLayer "L"); which is the same as strpbrk( "CONDUCTOR/L06" "L")
  • JuanCR
    +1 JuanCR over 3 years ago
    • Vote Up +2 Vote Down
  • MarkGorecki
    0 MarkGorecki over 3 years ago in reply to JuanCR
    Hi Juan, thank you very much, that worked!  I don't understand why substring didn't work, but I'm going to use your suggestion.
  • B Bruekers
    0 B Bruekers over 3 years ago
    Parsestring splits the string in a list of strings. Since you are interested in the 2nd part of the string use cadr().
    cadr(parseString("CONDUCTOR/L06" "/"))  -> "L06"
