  3. Set up the values of analysis modes of constriant manager...
  • State Verified Answer
  • Subscribers 21
  • Views 3852
Set up the values of analysis modes of constriant manager by SKILL
Natalia06
Natalia06 over 3 years ago
I want to set up the values of analysis modes  by SKILL.
I used axlCNSDedignValueSet() to set  Mechanical drii hole to mechanical drill hole spacing that has worked.
But I can not  set   Mechanical Drill Hole Checks Use Hole Spacing value on.
Please help me out.
Thanks.
axlCNSDedignValueSet('Mechanical_Drill_Hole_Checks_Use_Hole_Spacing  'on)   => It doesn't work.
  • mahimag
    mahimag over 3 years ago +1
    Hello Natalia06, DRC_MHOLE_AS_HOLE is not a mode. This is an attribute used to set the particular option. You may try something like following to set it through SKILL. axlDBAddProp((list nil) list…
  • Natalia06
    Natalia06 over 3 years ago in reply to mahimag +1 verified
    Thanks for your help.
  • MikeNV
    MikeNV over 3 years ago +1
    Hi Natalia06, There is a type-o axlCNSDedignValueSet -> axlCNSDesignValueSet axlCNSDedignValueSet('Mechanical_Drill_Hole_Checks_Use_Hole_Spacing 'on) -> axlCNSDesignValueSet('Mechanical_Drill_Hole_Checks_Use_Hole_Spacing…
  • mahimag
    0 mahimag over 3 years ago
    Hello Natalia06,
    axlDBAddProp((list nil) list("DRC_MHOLE_AS_HOLE" 1))
    After this if you open analysis mode, dialog you should see the option as 'On'.
  • Natalia06
    +1 Natalia06 over 3 years ago in reply to mahimag
  • MikeNV
    0 MikeNV over 3 years ago
    Hi Natalia06,
    axlCNSDedignValueSet('Mechanical_Drill_Hole_Checks_Use_Hole_Spacing  'on) -> axlCNSDesignValueSet('Mechanical_Drill_Hole_Checks_Use_Hole_Spacing  'on)
