  3. DE_changeViaNet_public Skill not working in 17.4 S029
  • State Verified Answer
  • Replies 10
  • Subscribers 23
  • Views 10107
LALITH
LALITH over 3 years ago
Hi eDave,
The Change via net is not loading in the Allegro 17.4 S029.
I get the below error message while loading.
SYNTAX ERROR found at line 1 column 5 of file C:/Skill/DE_changeViaNet_public.cxt
*Error* lineread/read: syntax error encountered in input
*Error* load: error while loading file - "C:/Skill/DE_changeViaNet_public.cxt" at line 0
Kindly help to make it work.
Lalith
  • steve
    steve over 3 years ago +3
    Not sure why the skill isn't working but this command is in the tools by default now so you may not need the skill anymore. You can hover over any via (General or Etch edit mode) and right click - Assign…
  • Kirti Sikri
    Kirti Sikri over 3 years ago +3
    To change the NetName on the Via, SKILL API is axlChangeNet(<via id>, <new name>) Changes the net an object is currently on. Restricted to shapes, filled rectangles (frectangles), pins and vias. Returns…
  • DE202408202727
    DE202408202727 over 3 years ago in reply to LALITH +2 verified
    Try loading the full path. ie loadContext(" C:/LALITH/Tools/DONOTDELETE/Skill/64bit/DE_changeViaNet_public.cxt")
  • steve
    0 steve over 3 years ago
    Not sure why the skill isn't working but this command is in the tools by default now so you may not need the skill anymore. You can hover over any via (General or Etch edit mode) and right click - Assign net to via then choose the net from the Options pane.
    • Vote Up +3 Vote Down
  • Kirti Sikri
    0 Kirti Sikri over 3 years ago
    Returns t when successful. Will not rip up clines or vias.
    Check Allegro SKILL documentation for more details
  • DE202408202727
    0 DE202408202727 over 3 years ago
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/1715.DE_5F00_changeViaNet_5F00_public.zip
    Try this one.
  • LALITH
    0 LALITH over 3 years ago in reply to DE202408202727
    Thanks Dave. I will try and let you know.
  • LALITH
    I get the below error message. I have placed the file in the location mentioned below.
    loadContext: could not open file - "C:/LALITH/Tools/DONOTDELETE/Skill/64bit/DE_changeViaNet_public.cxt"
    Kindly let me know your ideas to make it work.
    Thanks in advance
