  3. Pass data/values between two skill codes/allegro instan...
  • Replies 12
  • Subscribers 22
  • Views 10228
Pass data/values between two skill codes/allegro instances
mir0mik
mir0mik over 3 years ago
I'm working on a skill code that will in him self run another instance of allegro through batch call axlRunBatchDBProgram() and I would like to pass some variable/valuest to the batch instance as an input and vice versa.
Is this possible? Is there some way how to create/share variables between two programs?
Thanks!
Miro
  • TCHA
    TCHA over 3 years ago +1
    There can be a couple of ways. If you want to call another database, then yes for example sh("allegro <board-name") invokes another allegro as shown in the image below The command line arguments…
  • mir0mik
    mir0mik over 3 years ago in reply to B Bruekers +1
    Hi, tried some stuff with extracta but is quite slow... this code using ipcBeginProcess for extracta will crash when run on the library folder (about 4000+ psm/dra pairs) it probably would be OK if all…
  • mir0mik
    0 mir0mik over 3 years ago in reply to B Bruekers
    Hi ,
    I'm albe to to send recieve/run functions through the mps however, I would like to use it as in the simplified code below...
    - host code will initialize the mps host service
    - then will run another instance of allegro in batch mode
    - during the batch call it will load client.il skill code
    - this code will establish connection to the mps send "QQQ"  to host
    - receive "measage_from_host" display it
    - exit the batch instance of allegro
    However, I have issue when trying it as it will freeze when I try to use mpsImport - any help/idea what I'm doing wrong?
    EDIT: just want to add that when the CLIENT.il is run manually on a manually run instance of allegro it works as intended. It only freeze when run through the axlRunBatchDBProgram...
    Miro
    HOST.il
    defun( qqq_hostFunction ( qqq_clientData)
    printf( "Host function run %A\n" qqq_clientData)
    "message_from_host"
    qqq_mpsHostID = mpsExport( "qqq_Host" "qqq_Service" "69" list( 'qqq_hostFunction))
    axlRunBatchDBProgram( "allegro" "allegro %s -s run.scr empty.brd") ;will run -nogrpah later not used for debug
    mpsClose( qqq_mpsHostID)
    RUN.SCR
    skill load("CLIENT.il")
    #exit
    CLIENT.il
    axlUIConfirm( "Client Start")
    qqq_mpsClientID = mpsImport( "qqq_Host" "qqq_Service" "69" ) ;allegro will freeze when I use this line (when commented out with the next line too it will proceed to the axlOSExit
    axlUIConfirm( qqq_mpsClientID -> qqq_hostFunction( "QQQ")) ;thist should display the "message_from_host"
    axlOSExit(0)
  • B Bruekers
    0 B Bruekers over 3 years ago in reply to mir0mik
    I think the freeze is because you started the client board with axlRunBatchDBProgram(). This will block the host, so probably the MPS as well.
    Looking at your code I'm not sure what you want to achieve;
    1) running 2 instances of (non blocked! ) Allegro simutainusly and have user interaction with them at the same time.
       -> start Allegro with a shell command, use the mps system
    2) Extract data from the 2nd (client) brd file, and continue with the orignal 'host' design after finished
       -> save the host database, open 'client' design. Do whatever you need to do there and when finished re-open the host design.
       During the 'client' session all your skill variables are available. You can also 'store' polygons or things between the two boards.
       Only the dbid's are (logically) not shared between the boards
    So something like this:
    defun( start_client (clientFile)
        let( (hostDesign tmpFile)
            hostDesign = axlGetDrawingName()    ;store current design name, to open it later.
            tmpFile = axlTempFile(nil)
            axlOSFileCopy(clientFile tmpFile nil)    ;copy client file to temporary file, so we dont edit the orignal file.
            axlSaveDesign(?design axlCurrentDesign() ?noConfirm t)    ;save current work
            unwindProtect(        ;use this to make sure whatever happend in the first statement the 2nd statement is always called.
                when(axlOpenDesignForBatch(tmpFile "wf")
                    ;do whatever you need to do here.
                    run_during_client()
                axlOpenDesignForBatch(hostDesign "wf")
        errset(axlTempFileRemove(tmpFile))
        axlUIWUpdate(nil)
    defun( run_during_client ()
         axlUIConfirm("this is the client design")
  • mir0mik
    Hi B Bruekers,
    Thanks! That makes sense, I will check the documentation to set it not blocking (if possible)...
    What I want to achieve is this:
    - imagine we have a global library where some of the JEDECs can be updated (maybe some corrections etc...)
    - imagine you have a *.brd file that uses JEDECs from the global library
    - what I want to do is "check if the JEDECs (symdef) in the *.brd file are the latest version (I want to use VERSION_ID parameter)
    - the problem is that once the JEDECs is placed in the *.brd file it is stored in the "local library in the *.brd file"
    - my plan was to run a skill code that would get all "symdef"s and store them to a list and then I wanted to use axlLoadSymbol() to load the symbol from "global library" to check the VERSION _ID but axlLoadSymbol() will load the symbol from the "local library" if present.
    - so I came with an idea to run another instance of Allegro (in non graphic mode) > pass a list of symdefs from the original board > use axlLoadSymbol() to load them in the new empty *.brd > this way I would obtain the VERSION_IDs from the "global library" > pass the VERSION_IDs back to the first instance and close the second instance > check which VERSION_IDs do not match and alert the user but without refreshing the symbols in the original board and without saving the original board...
    So this is the idea that I want to achieve, maybe there is a better way how to get the VERSION_IDs from the global library instead of the board library...
    I wanted to avoid - saving the original design and make it a "one button" solution...
    Thanks!
    Miro
    EDIT:
    In the batch help for Allegro:
    [-mps<XXX>]
    - These are not typically not required. See MPS
    on-line documents for full description.
    I think this will be the way how to start it with the MPS ruining I now need to find what to pass to the option...
  • B Bruekers
    Now it is clear what you want to achieve :)
    There are a few ways to do such checks. Personally i would use extraca to read the version_id from the library directly.
    You could also do it with creating a new BRD file (empty), and place all symbols to be checked in it. Then read out all version_id's and return to the main design. (so the 2nd option with axlOpenDesignForBatch()) But I beleive this will cause a big delay/wait for the enduser.
    Check some old posts of me regarding this topic :
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-editor-skill/43609/compare-the-database-footprint-with-library-footprint--skill/
  • mir0mik
    Extracta may be good solution! Thanks for the idea... However, could you please look at the EDIT section of the previous post the -mps parameter? Any knowledge about this? Did you ever tried this?
