  3. Pass data/values between two skill codes/allegro instan...
  • Replies 12
  • Subscribers 22
  • Views 10236
Pass data/values between two skill codes/allegro instances
mir0mik
mir0mik over 3 years ago
I'm working on a skill code that will in him self run another instance of allegro through batch call axlRunBatchDBProgram() and I would like to pass some variable/valuest to the batch instance as an input and vice versa.
Is this possible? Is there some way how to create/share variables between two programs?
Thanks!
Miro
  • TCHA
    TCHA over 3 years ago +1
    There can be a couple of ways. If you want to call another database, then yes for example sh("allegro <board-name") invokes another allegro as shown in the image below The command line arguments…
  • mir0mik
    mir0mik over 3 years ago in reply to B Bruekers +1
    Hi, tried some stuff with extracta but is quite slow... this code using ipcBeginProcess for extracta will crash when run on the library folder (about 4000+ psm/dra pairs) it probably would be OK if all…
  • mir0mik
    0 mir0mik over 3 years ago in reply to B Bruekers
    it probably would be OK if all symbols are already placed in the brd file, but starting new process for each dra is slow...
    qqq_cnt = 0
    qqq_tmp = list( nil nil)
    foreach( qqq_element getDirFiles( "d:/Cadence/Master_Library_Current/PCB/.")
    when( substring( lowerCase( qqq_element) -4 4) == ".psm"
    when( isFile( sprintf( nil "d:/Cadence/Master_Library_Current/PCB/%s.dra" substring( qqq_element 1 strlen( qqq_element) - 4))) == t
    qqq_cid = ipcBeginProcess( sprintf( nil "extracta -q -s -k -r d:/Cadence/Master_Library_Current/PCB/%s.dra d:/Cadence/SKILL/ext_qqq.txt d:/Cadence/SKILL/out.txt" substring( qqq_element 1 length( qqq_element) - 4)))
    ipcWait( qqq_cid)
    qqq_inPort = infile( "d:/Cadence/SKILL/out.txt")
    while(
    gets( qqq_readOutLine qqq_inPort)
    tconc( qqq_tmp list( qqq_element qqq_readOutLine))
    close( qqq_inPort)
    qqq_cnt++
    println( qqq_cnt)
    car( qqq_tmp)
    however, this code I would like to run in the second instance of allegro (still not able to do that:( ), will be finished in about 2 seconds on the same folder...
    qqq_cnt = 0
    qqq_padstackID = axlLoadSymbol( "PACKAGE" substring( qqq_element 1 strlen( qqq_element) - 4))
    tconc( qqq_tmp list( qqq_element qqq_padstackID -> prop -> VERSION_ID))
    qqq_cnt++
    println( qqq_cnt)
    car( qqq_tmp)
    I don't know, maybe I'm doing something wrong with the extracta... I just need to run the axlLoadSymbol in an empty board and get back the list and it will be crazy fast...
    Miro
  • TCHA
    0 TCHA over 3 years ago in reply to mir0mik
    @mir0mik, any further update on this? Is the issue resolved?
