  3. ipcBeginProcess asynchronously execution code
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 5396
rttturn
rttturn over 3 years ago
 Cadance Allegro 17.2, Win10 x64
I am using ipcSkillProcess to communication with a .exe. I found that I need executed any line of command before the callback function is executed.
I can't get messages automatically.I want to implement exe to actively invoke skill to execute a particular program.
like the picture,
1. skill receive  "hello skill ipc,send data1&*()\\r\\r\\n"
2. I use ipcWriteProcess to send "ack1 \n"
3. .exe receive the message  "ack1 \n", send "get ack1,send data2" to skill
4. skill can't receive the message. if I executed any line of command(printf("111test")), I get the message "get ack1,send data2"
I'm upset about this problem ......
skill code:
cid = ipcBeginProcess("skill.exe" "" `ipc_callback `ipc_err `ipc_exit "skill.log")
procedure(ipc_callback(@rest ipc_callback_args)
    printf("--ipc begin receive--\n")
    printf("list length:%d\n" length(ipc_callback_args))
    printf("%s\n" car(ipc_callback_args))
    printf(nth(1 ipc_callback_args))
    printf("--ipc receive end--\n")
.exe(python) code:
import sys
sys.stdout.write("hello skill ipc,send data1&*()\n")
sys.stdout.flush()
c = sys.stdin.readline()
if c == 'ack1 \n':
sys.stdout.write('get ack1,send data2')
sys.stdout.flush()
shell result:
 Thank you,
rtttune
  • Kirti Sikri
    Kirti Sikri over 3 years ago in reply to rttturn +2 suggested
    Hello Eugene, Thanks for sending the code I have got following message on the Allegro Command window modying the code you shared. Code (skill and python are given below) Does it meet your requirements…
  • mahimag
    mahimag over 3 years ago +1
    Hello rttturn As I understand, you are trying to use IPC between SKILL and Python. In your code I see, by using IpcBeginProcess in skill you are calling SKILL executable, can you share some more details…
  • rttturn
    rttturn over 3 years ago in reply to mahimag +1
    I made an example to repeat the problem: --SKILL code: axlCmdRegister ( "test" 'test111 ) procedure ( dataH (cid data ) printf ( "cid: %L Msg: %s \n " cid data ) ipcWriteProcess ( cid "ack1…
  • mahimag
    0 mahimag over 3 years ago
    Hello rttturn As I understand, you are trying to use IPC between SKILL and Python. In your code I see, by using IpcBeginProcess in skill you are calling SKILL executable, can you share some more details about the requirement here?
  • rttturn
    0 rttturn over 3 years ago in reply to mahimag
    --SKILL code:
    axlCmdRegister("test" 'test111)
    procedure( dataH(cid data)
    printf("cid: %L Msg: %s\n" cid data)
    ipcWriteProcess( cid "ack1 \n" )
    procedure( simErr(cid err)
    printf("Error %L Msg: %s\n" cid err)
    ipcKillProcess(cid)
    procedure( simTerm(cid exit)
    printf("Simulator expired with exit status = %L %d\n" cid exit)
    procedure( test111()
    cid = ipcBeginProcess("D:\\skill Shell\\PY\\dist\\skill1.exe" "" "dataH" "simErr" "simTerm" "")
    --PY code(Compiled to skill1.exe using pyinstaller):
    import sys
    sys.stdout.flush()
    if c == 'ack1 \n':
    sys.stdout.flush()
    --allegro shell export:(only can receive message before execute the code "x=1" in shell)
  • Kirti Sikri
    0 Kirti Sikri over 3 years ago in reply to rttturn
    Hello Eugene,
    test.py:
    import sys
    sys.stdout.write("ABC hello skill ipc,send data1&*()\n")
    sys.stdout.flush()
    if c == 'ack1 \n':
    sys.stdout.flush()
    test.il:
    Call program test.py from ipcBeginProcess with full path.
    ipcKillProcess(cid)
    (drain (inSkill stdout))
    cid = ipcBeginProcess("C:/Python/python test.py" "" 'dataH 'simErr 'simTerm)
    Kirti
    • Vote Up +2 Vote Down
