  3. axlEnterEvent using of DONE during the active FORM
  • State Suggested Answer
  • Answers 1
  • Subscribers 22
  • Views 4186
JuriV
JuriV over 3 years ago
Hi everybody,
I noticed that the DONE function in axlEnterEvent doesn't works if the FORM (axlFormCreate) is active. Example:
axlCmdRegister( "test" 'test  ?cmdType "interactive")
form = axlFormCreate( (gensym) "FORM.form" nil test_run t)
procedure( test_run(form)
case( form -> curField  ; funktioniert nicht mit "fields" anstelle von curField
(‘button1
       test1()
(‘button2
       test2()
);end case
); end procedure test_run
procedure( test1()
        loop = t
        while( loop
            event = axlEnterEvent(list('PICK ‘DONE ‘CANCEL nil nil)
            caseq(event->type
                ('PICK
                         do something one
                 ); end PICK
                 (‘DONE
                     do something two
                 ); end DONE
If the form appears I can check the button 1 starting test 1. By PICK the "do something one" is started. If I click right mouse button in order making DONE I see   "Snap pick to" only. My FORM is active and I guess that is the problem, why I dont' see the DONE function. I work in the Command mode not in the SKILL mode
Some ideas how it could be fixed?
  • B Bruekers
    B Bruekers over 3 years ago +1 suggested
    Because you call a Form which has a certain program mode, interactive or general you cannot call directly a different (interactive) command such like axlEnterEvent(). To do such you need to register…
  • John T
    0 John T over 3 years ago
    Hi JuriV, ok this time let us have a look into that for you by consulting with a skill expert. We shall get back to you on that within a few days.
  • B Bruekers
    0 B Bruekers over 3 years ago
    To do such you need to register the test1 function as a 'sub command' and call this command with axlShell().
    According to the api:  "sub_cmd"  Must be called inside an interactive command. Use for pop-ups.
    Something like this:
    ;register a 'sub command'
    axlCmdRegister("startTest1" 'test1 ?cmdType "sub_cmd")
    ;when deinitializing the program do a unregister command.
    axlCmdUnregister("startTest1")
        ('button1
            axlShell("startTest1")
        ('button2
               test2()
    );end case
    procedure( test1()
        loop = t
        while( loop
            event = axlEnterEvent(list('PICK 'DONE 'CANCEL nil nil)
            caseq(event->type
            ('PICK
                do something one
            ); end PICK
            ('DONE
                do something two
            ); end DONE
  • John T
    Hi JuriV, it seems you have received a good answer from the community. (thank you B Bruekers). If you are satisfied with the donated information then you have the ability to vote your thanks. Simply select MORE at the end of the comment and select "Verify Answer".
