  3. Adding menu item at bottom of list in Layout 22.1
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 2336
Jim OMahony
Jim OMahony over 3 years ago
I have added a menu item under the Tools menu using the following command:
axlUIMenuRegister( "padeditdb" '( ("Create a Via according to IPC rules..." "EXL_ViaStack"  ) ) )
This adds the command at the top of the list. Can anyone tell me how to add the command at the bottom of the list ?
Thanks.
  • Jim OMahony
    Jim OMahony over 2 years ago in reply to mahimag +1 suggested
    Thanks mahimag. I was trying to find a way to use the axlUIMenuRegister command as it is possible to use on a single line. I have ended up with the following code which takes 7 lines : procedure( PadMenuInsert…
  • mahimag
    0 mahimag over 3 years ago
    axlUIMenuRegister, allows you to register menu items to be loaded when Allegro loads a new menu. It is a combination of axlUIMenuFind and axlUIMenuInsert.
    axlUIMenuFind has the option of top or bottom which indicates the axlUIMenuInsert to insert the value in that location. For example:
    q = axlUIMenuFind( nil -1 'bottom)
    z = axlUIMenuInsert(q "Google" "http ">http://google.com" )
  • Jim OMahony
    0 Jim OMahony over 2 years ago in reply to mahimag
    procedure( PadMenuInsert(t_menufile)
    let(( q m )
    q = axlUIMenuFind( nil "padeditdb" 'bottom)
    m = axlUIMenuInsert( q "Create a Via according to IPC rules..." "EXL_ViaStack" )
    );let
    );defun
    axlTriggerSet('menu  'PadMenuInsert)
    This puts my menu in Tools>Padstack at the bottom of the list.
