  3. poly_relationship_and = axlPolyOperation( poly1 poly2 'AND...
  • Subscribers 20
  • Views 3094
poly_relationship_and = axlPolyOperation( poly1 poly2 'AND), E- (SPMHA1-507): PolyBool has hit an assert.
kobe882424
kobe882424 over 2 years ago
hi,
Have you encountered the following problem?
thanks
Skill > poly1
(poly:000001900D87E308)
Skill > poly2
(poly:000001900D87A1A0)
Skill > poly_relationship_and = axlPolyOperation( poly1 poly2 'AND)
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi kobe882424
    try this code:
    if(poly1->holes != nil && poly2->holes != nil then poly_relationship_and = axlPolyOperation( poly1 poly2 'AND) else print("Need process holes"))
    HoangKhoi,
  • kobe882424
    0 kobe882424 over 2 years ago in reply to Hoangkhoipcb
    Thanks HoangKhoi. the poly'holes is indeed nil.
    did poly's holes must be  not nil?
    if it'holes is nil, what shall i do ?
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to kobe882424
    The poly hole is not reason. I've tried there's not issue error "E- (SPMHA1-507): PolyBool has hit an assert."
    Please to searching solution other.
    • Vote Up -1 Vote Down
  • kobe882424
    Thanks HoangKhoi.
    i tried  and found that the quetion exists in one pcb design but not in other pcbs with the same allegro version(17.2S079), but  i don't know the difference.
