  3. Using extracta to extract symbol properties in SKILL
  • State Verified Answer
  • Subscribers 21
  • Views 8176
AsbjornEdvalds
AsbjornEdvalds over 2 years ago
I want to extract symbol properties from the symbols used in the board, but from the library files. That is, I want to be able to verify that some properties have not changed in the library from the symbols in the board file. E.g., I have a 0805 resistor which has a "DFA_DEV_CLASS:smdr_res" and it might have changed in the library to "DFA_DEV_CLASS:smdr_small". Being able to report this would quickly make it possible to see if the symbol in the board needs to be refreshed, as doing a full refresh regularly of all components in a design is not a wanted behavior.
I wanted to use the extracta function and ipcBeginProcess to do this bidding, but it seems that properties of symbols are not supported using extracta. Following is the relevant snippet of the code which I started writing:
extr_opt = axlDMOpenFile("ALLEGRO_TEXT", axlTempFile( t ), "w")
fprintf(extr_opt "BOARD\nDATE_MODIFIED\nDFA_DEV_CLASS\nEND\n")
fname = get_filename(extr_opt)
axlDMClose(extr_opt)
LibFile = axlDMFindFile("ALLEGRO_PACKAGE_DB" "0805" "r")
axlMsgPut("LibFile: %L" LibFile)
cid = ipcBeginProcess(lsprintf("extracta -s -q -k -r \\\"%s\\\" \\\"%s\\\" " LibFile fname))
ipcWait(cid 5 5)
result = ipcReadProcess(cid 20)
axlMsgPut("read: %L" result)
Is this something that is possible using SKILL?
I am using 17.4-2019 S035.
Thanks in advance!
  • DE202408202727
    DE202408202727 over 2 years ago in reply to AsbjornEdvalds +1 verified
    Change ALLEGRO_PACKAGE_DB to ALLEGRO_DRAWING. I'm not sure why you would use an IPC process to do this. Why not use axlRunBatchDBProgram? This works for me: defun( My_extractSymProperty (draName) viewFile…
  • JuanCR
    0 JuanCR over 2 years ago
    Hi AsbjornEdvalds
    I believe I understand what you want to do but I'm not clear about extracta not being able to access symbol properties ... If I launch the custom report UI I can see this:
    Am I missing anything?
  • AsbjornEdvalds
    0 AsbjornEdvalds over 2 years ago in reply to JuanCR
    Hi Juan,
    Running the "reports" function within a .dra file will output the correct fields, but when trying to use the extracta command from the ipcBeginProcess using SKILL from within a .brd file, nothing is exported. I have tried other properties and none seem to work.
    In my code above, I am inputting the following extract information into the extracta executable, which in turn does not return anything.
    BOARD
    DATE_MODIFIED
    DFA_DEV_CLASS
    END
  • AsbjornEdvalds
    No one got any ideas to how I might solve this?
  • DE202408202727
    +1 DE202408202727 over 2 years ago in reply to AsbjornEdvalds
    viewFile = "props.view"
    p = axlDMOpenFile("ALLEGRO_TEXT", viewFile, "w")
    fprintf(p, "BOARD\n")
    fprintf(p, "DFA_DEV_CLASS\n")
    axlDMClose(p)
    dra = axlDMFindFile("ALLEGRO_DRAWING", draName, "r")
    outFileName = "draPropTest.txt"
    sprintf(cmd, "extracta -s -q -w -r %s %s %s", dra, viewFile, outFileName)
    axlRunBatchDBProgram("extracta", cmd, ?noUnload t)
  • AsbjornEdvalds
    0 AsbjornEdvalds over 2 years ago in reply to DE202408202727
    Hi Dave, great answer as always. The ALLEGRO_DRAWING seems to have been my issue.
    My plan was to use the IPC process to be able to get the extract back to the skill program to use for more processing.
