  3. Creating a multiple drill padstack in SKILL with custom...
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 6050
Creating a multiple drill padstack in SKILL with custom pattern
Brother Forage
Brother Forage over 2 years ago
I'm trying to figure out how to create (custom) multiple drill in SKILL.
my kung-fu of searching help files and forums may be weak but all i find is referring to 17.2 or older versions.
using
padID=axlLoadPadstack("myPadWithPolarDrillPattern")
padID->??
to see if it can bring some light in the matter doesn't help either as no matter the (custom) drill pattern made on padstack editor, the drill reported is
multiDrillData   (1 1 0.0 0.0 nil)
Can I make a list of drills in the same manner as a pad list and submit as drill data?
I am using revision 17.4 S32 as IT policies prohibits me from install latest versions or hotfixes.
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +1 suggested
    Hi Brother Forage ! Do you try to combine Skill and file.scr file yet? This is not solution perfect. I think them help a lite bit Can refer this post. community.cadence.com/.../multDrill.txt …
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi Brother Forage !
    Fullscreen multDrill.txt Download
    axlCmdRegister("mult_drill" 'mult_drill )
    (defun mult_drill ()
    	name = "mutlDrillPad"
        drill_data = make_axlPadStackDrill(
    		?holeType  'CIRCLE_DRILL
    		?drillDiameter 5
    		?plating 'PLATED
    		?figure 'SQUARE
    		?figureSize 60:60
    		?drillChar "abc"
    	pad_list = nil
    	pad = make_axlPadStackPad(?layer "TOP",
    	?type 'REGULAR, ?figure 'CIRCLE,
    	?figureSize 80:80)
    	pad_list = cons(pad pad_list)
    	pad = copy_axlPadStackPad(pad)
    	pad->type = 'REGULAR
    	pad->layer = "BOTTOM"
    	pad->figure = 'CIRCLE
    	pad->figureSize = 80:80
    	ps_id = axlDBCreatePadStack(name, drill_data, pad_list t)
    	Out_File = outfile("./mult_drill.scr" "w")
    	fprintf(Out_File "setwindow pcb\n")
    	fprintf(Out_File "trapsize 16783\n")
    	fprintf(Out_File "etchedit\n")
    	fprintf(Out_File "padeditdb\n")
    	fprintf(Out_File "setwindow form.mini\n")
    	fprintf(Out_File "FORM mini padlist %s\n" name)
    	fprintf(Out_File "padeditcur mult_drill_1.scr\n")
    	fprintf(Out_File "prepopup 0.0 0.0\n")
    	fprintf(Out_File "done\n")
    	close(Out_File)
    	Out_File = outfile("./mult_drill_1.scr" "w")
    	fprintf(Out_File "QtSignal GuidedTabsParent GuidedTabs currentChanged Drill\n")
    	fprintf(Out_File "QtSignal GuidedDrillTab PatternStyle CurrentIndexChanged Polar\n")
    	fprintf(Out_File "QtSignal GuidedDrillTab polarRadius editingFinished %L\n" 10.0)
    	fprintf(Out_File "QtSignal GuidedDrillTab polarCopies editingFinished %d\n" 6)
    	fprintf(Out_File "QtSignal MainWindow UpdateToDesignExit triggered\n")
    	fprintf(Out_File "QtSignal pseCheckBrowser Close clicked\n")
    	fprintf(Out_File "QtFillin Yes\n")
    	close(Out_File)
    	axlShellPost("replay mult_drill.scr")
    	axlPadstackToDisk(name)
    I hope this helps.
    HoangKhoi.
