  3. Creating a multiple drill padstack in SKILL with custom...
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 6049
Creating a multiple drill padstack in SKILL with custom pattern
Brother Forage
Brother Forage over 2 years ago
I'm trying to figure out how to create (custom) multiple drill in SKILL.
my kung-fu of searching help files and forums may be weak but all i find is referring to 17.2 or older versions.
using
padID=axlLoadPadstack("myPadWithPolarDrillPattern")
padID->??
to see if it can bring some light in the matter doesn't help either as no matter the (custom) drill pattern made on padstack editor, the drill reported is
multiDrillData   (1 1 0.0 0.0 nil)
Can I make a list of drills in the same manner as a pad list and submit as drill data?
I am using revision 17.4 S32 as IT policies prohibits me from install latest versions or hotfixes.
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +1 suggested
    Hi Brother Forage ! Do you try to combine Skill and file.scr file yet? This is not solution perfect. I think them help a lite bit Can refer this post. community.cadence.com/.../multDrill.txt …
  • JuanCR
    0 JuanCR over 2 years ago
    Hello Brother Forage,
    Have you checked the following article:
    Article (20479876) Title: How to read and make Padstacks using Allegro SKILL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090t3UUAQ
    I'll attach the document to this post too.   MakePadstackInAllegroSkill.pdf
    Let me know if it helped.
  • Brother Forage
    0 Brother Forage over 2 years ago in reply to JuanCR
    Hi and thanks, but it unfortunately doesn't really help, I should have mentioned I had already read that document,
    the reason I have come anywhere in creating padstacks in skill is that document, but it is referencing revision 17.2.
    The document describes how to make a through-hole padstack with one hole.
    Hole array is supported in 17.2, and should not be a big problem to create, if not immediately understood,
    it is possible to analyze by creating a few padstacks with hole arrays in the padstack editor ,
    then examining the result using axlLoadPadstack  and ->??.
    However, polar or custom hole patterns can't be examined this way as the drill reported is "multiDrillData   (1 1 0.0 0.0 nil)" every time.
  • DE202408202727
    0 DE202408202727 over 2 years ago
    I'm unclear on where you are getting stuck. Creating a padstack involves quite a few steps. However, the key step for creating a multidrill padstack is adding ?multiDrillData to the make_axlPadStackDrill command: Something like this:
    make_axlPadStackDrill(?drillDiameter drillDiameter, ?figure figure, ?figureSize figureSize ?plating "PLATED" ?drillChar drillChar ?multiDrillData list(x y 0.00))
    I hope this helps
  • Brother Forage
    0 Brother Forage over 2 years ago in reply to DE202408202727
    I try to be clear, but fail to explain what I want to do.
    With multidrilldata in make_axlPadstackDrill it is possible to define a grid of x * y holes with x and y clearance. rectangle=yes, rhombus=yes, triangle=no.
    If I want a drill pattern of a pentagon, or looking like the big dipper (for whatever reason) it can be done in the padstack editor with polar or custom drill patterns, but I fail to understand how to do it in skill.
    In short, all that can be done in the padstack editor, I want to do in skill.
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to Brother Forage
    Thanks for explaining. I can't see a solution. Cadence hasn't documented this and I can't see a work-around. I think you need to raise an enhancement request. Let us know how you get on.
