  3. Axlmeterupdate issue with macro
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3162
ABIKRISHNA
ABIKRISHNA over 2 years ago
After running the substrate.scr file in skill axlmeterupdate command is not working. Is there any solution for this?
  • mahimag
    mahimag over 2 years ago in reply to ABIKRISHNA +1 suggested
    Hi ABIKRISHNA , It is working fine in my case. This might be database or version specific, we will contact you through another channel to get more information from you on this.
  • mahimag
    0 mahimag over 2 years ago
    Hi ABIKRISHNA, can you share more about this script (scr) file? If you can can share the content of scr that will give us more clarity.
  • ABIKRISHNA
    0 ABIKRISHNA over 2 years ago in reply to mahimag
    setwindow pcb
    generaledit
    artwork
    setwindow form.film_control
    FORM film_control missing_films
    FORM film_control ok
    setwindow pcb
    generaledit
    This is the macro script file which i am running. Macro script file is running properly.
    After running any macro file axlmeterupadate and axlmeterdestroy function is not working. It seems axlmeterupdate and axlmeterdestroy is not working after running the macro file.
  • mahimag
    0 mahimag over 2 years ago in reply to ABIKRISHNA
    Hi ABIKRISHNA, It is working fine in my case. This might be database or version specific, we will contact you through another channel to get more information from you on this.
  • ABIKRISHNA
    0 ABIKRISHNA over 1 year ago in reply to mahimag
    Hi Mahimag, I am having a 10 minutes process skill so i created a meter and update it continuously after the single process completion. In that skill I used macro script file to run, after that axlmeterupadate and axlmeterdestroy function is not working fine.
    Before running the macro script axlmeterupdate is working fine after the macro script running it is not working.
