  3. Get names of padstacks used in footprint via command pr...
  • State Verified Answer
  • Answers 1
  • Subscribers 20
  • Views 2853
Get names of padstacks used in footprint via command prompt
piorog
piorog over 2 years ago
Is there any way to get names of padstacks used in footprint without having to checking it directly in Allegro i.e. via command prompt? I only know that I can check the footprint software version using dbstat, but how to get other data in a similar way?
  • piorog
    piorog over 2 years ago in reply to piorog +1 verified
    Oh, it occured that all I needed is to just replace "pad" with "psu" in above command.
  • DE202408202727
    0 DE202408202727 over 2 years ago
    Try the "Padstack Usage Report"
  • piorog
    0 piorog over 2 years ago in reply to DE202408202727
    Hey! Thank you for the answer. It does the job, but how to use it outside the footprint using windows command line? I have to do it on a large number of footprints and doing it manually would take too much time.
    I have found that the report -v pad command works almost perfectly:
    but it gives a lot of unneccesary data including (unpurged) padstacks which are not used in the footprint.
  • piorog
    +1 piorog over 2 years ago in reply to piorog
