  3. Regarding skill commands
  • State Verified Answer
  • Replies 18
  • Answers 2
  • Subscribers 21
  • Views 13988
archanav
archanav over 2 years ago
Hi All,i just started learning Skill scripting for automating the my works in allegro. While doing that i come across two commands for changing the user units. They are as follows below
axlDBChangeDesignUnits
axlMKSConvert
i want to know the difference between these two. and my current requirement is to change the units from mils/inches/microns/centimeters to millimeters using skill scripting. Could any one help me to do this one ? and one more to thing is how we need to measure the line segments width in the current layer using skill script.
Thanks in advance for your support.
  • DE202408202727
    DE202408202727 over 2 years ago in reply to archanav +2 verified
    You can't just jump into Skill like this and start typing then expect much help here. You need to do some study! However, the syntax you want is: axlDBChangeDesignUnits("millimeters" 3)
  • archanav
    archanav over 2 years ago in reply to DE202408202727 +2
    Hi dave what is the difference between this pin DBID and the command axlPinData shown above ? and while working in .dra file how we need to modify these syntax symRefDes = symDbid->refdes and symName …
  • DE202408202727
    DE202408202727 over 2 years ago +1 suggested
    Welcome to Skill! Use axlDBChangeDesignUnits to change the design units (and accuracy). axlMKSConvert is a mathematical function. To measure line segments widths you need to obtain the line segment…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi archanav!
    Welcome to Skill, too.
    This is a example, you can refer . i wiish help you study SKill well.
    HoangKhoi.
  • archanav
    0 archanav over 2 years ago in reply to DE202408202727
    Thanks for your reply and sure i will continue to learn skill. in some of the videos i saw by typing skill in command window they changed to skill console. I followed that one in the starting. Now i changed that practice.
     while working into this i got  one doubt  that is, is it possible to read the pin pad stack information  (drill size ,pad value value if its through hole and  pad x and y dimension if its SMPT pin ) present in the .dra file ?
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to archanav
    Look at the pin definition attributes. Ie. pinDBID ->definition ->??
  • archanav
    +1 archanav over 2 years ago in reply to DE202408202727
    Hi dave what is the difference between this pin DBID  and the  command axlPinData shown above ? and  while working in .dra file how we need to modify these syntax symRefDes = symDbid->refdes and symName = symDbid->name to display the symbol name and ref des?
    • Vote Up +2 Vote Down
  • DE202408202727
    xlPinData is an array, not a function.
    To answer your second question: A dra does not have a reference designator and the name is the design name axlCurrentDesign().
