  3. Regarding skill commands
  • State Verified Answer
  • Replies 18
  • Answers 2
  • Subscribers 21
  • Views 13998
archanav
archanav over 2 years ago
Hi All,i just started learning Skill scripting for automating the my works in allegro. While doing that i come across two commands for changing the user units. They are as follows below
axlDBChangeDesignUnits
axlMKSConvert
i want to know the difference between these two. and my current requirement is to change the units from mils/inches/microns/centimeters to millimeters using skill scripting. Could any one help me to do this one ? and one more to thing is how we need to measure the line segments width in the current layer using skill script.
Thanks in advance for your support.
  • DE202408202727
    DE202408202727 over 2 years ago in reply to archanav +2 verified
    You can't just jump into Skill like this and start typing then expect much help here. You need to do some study! However, the syntax you want is: axlDBChangeDesignUnits("millimeters" 3)
  • archanav
    archanav over 2 years ago in reply to DE202408202727 +2
    Hi dave what is the difference between this pin DBID and the command axlPinData shown above ? and while working in .dra file how we need to modify these syntax symRefDes = symDbid->refdes and symName …
  • DE202408202727
    DE202408202727 over 2 years ago +1 suggested
    Welcome to Skill! Use axlDBChangeDesignUnits to change the design units (and accuracy). axlMKSConvert is a mathematical function. To measure line segments widths you need to obtain the line segment…
  • archanav
    0 archanav over 2 years ago in reply to DE202408202727
    Hi Dave,
    Thanks for your reply. what does the array of the XlPinData indicates? and .dra file w use to create footprints and we will assign ref des to the footprint in both assembly layer and silkscreen layer (like U? for  IC components etc...,)so to get the information about ref des i asked how to use symrefdes  for .dra files.
    my new query is i went through your reply for the query  silk to solder check in allegro PCB and creating Context file.
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-design/31029/autosilkutils-error
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/allegro-x-scripting-skill/40034/creating-context-file
    i tried using the file -https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/AutosilkUtils_5F00_public.zip.
    but i am getting error like this. May i know where i am doing mistake?
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to archanav
    I haven't got a 23.1 version of the code yet. I'm waiting on a  license server upgrade.
    The cxt file that you have won't work in 23.1
  • archanav
    I am using 22.1 version.
  • DE202408202727
    Same problem, sorry.
  • archanav
    ok. are there any other ways to get the clearance between silk and solder mask for these versions?
