  3. Regarding skill commands
  • State Verified Answer
  • Replies 18
  • Answers 2
  • Subscribers 21
  • Views 14009
archanav
archanav over 2 years ago
Hi All,i just started learning Skill scripting for automating the my works in allegro. While doing that i come across two commands for changing the user units. They are as follows below
axlDBChangeDesignUnits
axlMKSConvert
i want to know the difference between these two. and my current requirement is to change the units from mils/inches/microns/centimeters to millimeters using skill scripting. Could any one help me to do this one ? and one more to thing is how we need to measure the line segments width in the current layer using skill script.
Thanks in advance for your support.
  • DE202408202727
    DE202408202727 over 2 years ago in reply to archanav +2 verified
    You can't just jump into Skill like this and start typing then expect much help here. You need to do some study! However, the syntax you want is: axlDBChangeDesignUnits("millimeters" 3)
  • archanav
    archanav over 2 years ago in reply to DE202408202727 +2
    Hi dave what is the difference between this pin DBID and the command axlPinData shown above ? and while working in .dra file how we need to modify these syntax symRefDes = symDbid->refdes and symName …
  • DE202408202727
    DE202408202727 over 2 years ago +1 suggested
    Welcome to Skill! Use axlDBChangeDesignUnits to change the design units (and accuracy). axlMKSConvert is a mathematical function. To measure line segments widths you need to obtain the line segment…
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to archanav
    I'm not sure sorry. I'm currently using 17.2.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to Hoangkhoipcb
    What is the skill routine axlShapeArea() used in your example code?
    It's not documented from what I can find...
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to DavidJHutchins
    hi DavidJHutchins!
    i wish i help you something.
    HoangKhoi.
