  3. extracting pad stack information through skill scriptin...
  • State Verified Answer
  • Subscribers 21
  • Views 5805
extracting pad stack information through skill scripting
archanav
archanav over 2 years ago
Hi Dave, i used the below functions to get the pad dimension and solder mask value provided in the pad stack editor. using both I am not getting the required output. Please let me know what i need to do to get the pad size given in the design layer section under regular pad column and solder mask value given in the mask layer (top/bottom) in mm.
skill > padStackId=axlLoadPadstack("Padstack name")
skill> pad=axlDBGetPad(padStackId "layer" "regular")
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to archanav +1 verified
    Below is some sample code that reports the pad info in MM units: procedure(get_pad_info() let((popup pad llx lly urx ury Dx Dy) popup = axlUIPopupDefine( nil (list (list "Done" 'axlFinishEnterFun) (list…
  • archanav
    archanav over 2 years ago in reply to DavidJHutchins +1
    Hi David, Thanks for your great support and thanks for sharing this. This is working well for all types of pins. and I added the code part to get the bottom layer pins information and paste mask value…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    pad=axlDBGetPad(padStackId "ETCH/TOP" "regular")
    pad=axlDBGetPad(padStackId "PIN/SOLDERMASK_TOP" "regular")
    (llx = (caar((pad->bBox)) + (xCoord (pad->offset))))
    (lly = (cadar((pad->bBox)) + (yCoord (pad->offset))))
    (urx = (caadr((pad->bBox)) + (xCoord (pad->offset))))
    (ury = (cadadr((pad->bBox)) + (yCoord (pad->offset))))
    (Dx = (urx - llx))
    (Dy = (ury - lly))
  • archanav
    0 archanav over 2 years ago in reply to DavidJHutchins
    Hi David,
    thanks for your reply. sorry for asking you again. i executed like this. but I want in x and y dimension values whatever we had given in pad stack editor and that to in mm. and i also i  tried like this by importing the il file but not getting the output what I required.
      file
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago in reply to archanav
           popup = axlUIPopupDefine( nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
            axlUIPopupSet( popup)
            axlSetFindFilter( ?enabled list("noall") ?onButtons "noall")
            axlSetFindFilter( ?enabled list("pins" "vias") ?onButtons list("pins" "vias"))
            axlMKSConvert(nil "MM")
            (while axlSelect()
                progn(
                    (pad = axlDBGetPad(car(axlGetSelSet()) "etch/top" "regular"))
                    (Dx = (urx - llx))
                    (Dy = (ury - lly))
                    if( ((pad->figureName) == "CIRCLE") || ((pad->figureName) == "OCTAGON")  || ((pad->figureName) == "SQUARE")  || ((pad->figureName) == "DONUT") then
                       axlMsgPut("Pad figure type : %s size %fmm\n" pad->figureName Dx)
                    else
                       if( ((pad->figureName) == "RECTANGLE") || ((pad->figureName) == "OBLONG_X") || ((pad->figureName) == "OBLONG_Y") || ((pad->figureName) == "ROUNDED_RECTANGLE")  || ((pad->figureName) == "CHAMFERED_RECTANGLE") then
                          axlMsgPut("Pad figure type : %s width %fmm height %fmm\n" pad->figureName Dx Dy)
                       else
                          axlMsgPut("Pad figure type : %s Unknown Size\n" pad->figureName )
                    (pad = axlDBGetPad(car(axlGetSelSet()) "PIN/SOLDERMASK_TOP" "regular"))
                    (Dx = (urx - llx))
                    (Dy = (ury - lly))
                       axlMsgPut("Paste figure type : %s size %fmm\n" pad->figureName Dx)
                    else
                          axlMsgPut("Paste figure type : %s width %fmm height %fmm\n" pad->figureName Dx Dy)
                       else
                          axlMsgPut("Paste figure type : %s Unknown Size\n" pad->figureName )
  • archanav
    Hi David, Thanks for your great support and thanks for sharing this. This is working well for all types of pins. and I added the code part to get the bottom layer pins information and paste mask value information. Currently I am working on fetching the line segments width present in package geometry assembly and silkscreen layer and changing as per my requirement through script only. for this one i am using cwidth.il file but there I changed the layer name and did some of the modifications. still not able to achieve my requirement. I attached my file here please see and let me know where I am missing. https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/137/Assy_5F00_silk_5F00_width.zip
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to archanav
    Below is some info on getting pin info I found by looking at old postings:
    - You can get the internal definition (DEFAULT INTERNAL) by doing using the 'internal symbol as the 2nd arg to GetPad
              pad = axlDBGetPad(pin 'internal "REGULAR")
    - For toleranace you need to access the padstack. For example if you have a pin dbid assigned to variable "pin". Then you would:
         def = pin->definition     ; get padstack
         ; tolerance is represented as a list of (+tol -tol) in design units (float)
          printf("tol %L\n" def->holeTolerance)
