  3. How to set the spacing of wired CLINE using SKILL
  • State Verified Answer
  • Subscribers 20
  • Views 3314
youngmin
youngmin over 2 years ago
Just like the title.
I would like to know how to adjust the spacing of placed CLINE using SKILL.
I already have the SPREAD_CLINE SKILL, which distributes the area at an even distance when we specify the area, but I want the spacing of the placed clines to change when we enter the spacing like the 'route spacing' function.
Plz Somebody Help Me.
  • JuanCR
    JuanCR over 2 years ago +1 verified
    Hi younmin, I can think of a few ways to do this depending on the trigger action. I have a few follow-up questions: - What is this "route spacing" function you mention? - Do you want the Clines…
  • JuanCR
    +1 JuanCR over 2 years ago
    Hi younmin,
    - Do you want the Clines to automatically change their spacing based on a spacing DRC change?
    - Why can't you reuse the SPREAD_CLINE code with a different spacing value?
  • youngmin
    0 youngmin over 2 years ago in reply to JuanCR
    HI JuanCR
    1. the latest feature is the 'route spacing' function in 'add connect', which allows you to set the spacing of multiple wires by entering a number.
    2. DRC spacing is good, but I would like to have it adjusted by entering a number for flexibility.
    3. I've tried to modify the existing code, but after repeated attempts, I've failed, so I'm looking for help. Also, other files are locked and I can't modify them.
    I'm studying the SKILL language, but I don't have the skills to perform the function yet.
    Thank you for your interest.
  • youngmin
    0 youngmin over 2 years ago in reply to youngmin
    Additionally, changing the spacing does not mean changing the cm rule, it simply means adjusting the spacing of the clines to free up space and clean up the board.
