  3. How to assign external DRC ?
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3842
Uri Chaplin
Uri Chaplin over 2 years ago
I created a custom DRC checker and used  axlDBCreateExternalDRC.
 System DRC information includes 2 elements
but when I create external DRC with this parameters :
axlDBCreateExternalDRC( "VIAS problem", second_item->xy, drc_layer, second_item, via->xy, problem)
 I see only 1 element twice. You can see that in this place there exist 2 different vias ( TH and BL) but in report only one.
What needs change in parameters to get information about 2 elements?
  • DE202408202727
    DE202408202727 over 2 years ago +1
    Is this better? axlDBCreateExternalDRC( "VIAS problem", second_item->xy, drc_layer, list(via, second_item), via->xy, problem)
  • DE202408202727
    0 DE202408202727 over 2 years ago
    Is this better?
  • Uri Chaplin
    0 Uri Chaplin over 2 years ago in reply to DE202408202727
    Yes, Dave. Thanks ! Glad tto hear from you.
  • Uri Chaplin
    0 Uri Chaplin over 2 years ago in reply to Uri Chaplin
    BTW now in log I see 3 items and last it is 2 elements again :
    LISTING: 3 element(s)
    Item 1 < VIA >
    origin-xy: (8153.46 2383.38)
    part of net name: GND
    Padstack name: VIA24D12
    Type: Through Plated
    Circle_drill : 12.00
    Item 2 < VIA >
    origin-xy: (8158.00 2388.00)
    Padstack name: VIA1-4
    Type: Bbvia Plated
    Circle_drill : 6.00
    Item 3 < DRC ERROR >
    Class: DRC ERROR CLASS
    Subclass: BOTTOM
    Origin xy: (8158.00 2388.00)
    Constraint: Externally Determined Violation
    Constraint Set: VIAS problem
    Constraint Type: EXTERNAL REFERENCE
    Constraint value: None
    Actual value: close_via
    Element type: VIA
    Class: VIA CLASS
    Element type: VIA
    Class: VIA CLASS
    Type: Bbvia Plated
    Circle_drill : 6.00
    ~ ~ ~ ~ ~ ~ ~end-of-file~ ~ ~ ~ ~ ~ ~
    If it posible to short it ?
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to Uri Chaplin
    Hi Uri,
    I'm not aware of any method to shorten the dialog contents. This might be a request for Cadence.
  • Uri Chaplin
    it's ok. no problem.
