  3. How to make a skill form be resizable
  • Subscribers 21
  • Views 2867
NNNNNNing
NNNNNNing over 2 years ago
Recently I want to make a skill form to be resizable, cause there is a list in the form, and I want to resize the form to let the list show more items.
I read the axlFormFlexDoc, and found maybe this canbe completed with :FLEXMODE edgegravity
But somehow, the list or other items always align to the right bottem to the form when I try to grag the form to be lagger. Then the left part of the form is empty, cause the items are all in the right part.
Below are my code and the form capture:
FLEX refresh_list 0 0 0 1
FLEX save_list 0 0 0 1
Thanks!
  • JuanCR
    JuanCR over 2 years ago +1
    Hi NNNNNNing You're on the right track but, in order to get what you're describing, I believe your code should be like this: FLEX refresh_list 0 0 1 0 FLEX save_list 0 0 1 0 Let me know if this fixes your…
  • NNNNNNing
    NNNNNNing over 2 years ago in reply to JuanCR +1
    Thanks a lot for your kindly help! But unfortunately it doesn't work. It still locked to the right and bottom edge. I checked the article, and made some changes to the code, but it still doesn't work …
  • JuanCR
    JuanCR over 2 years ago in reply to NNNNNNing +1
    Hi NNNNNNing I'll contact you separately via email so we can discuss your code in detail.
  • JuanCR
    Hi NNNNNNing
    Let me know if this fixes your issue.
    For additional information on the topic, please check the attached AppNote down below or visit the following link:
    Article (20463837) Title: How to Resize GUI in Allegro SKILL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000007MXYnEAO
    ResizingGUI_AllegroSKILL_updated.pdf
  • NNNNNNing
    Thanks a lot for your kindly help! But unfortunately it doesn't work. It still locked to the right and bottom edge. I checked the article, and made some changes to the code, but it still doesn't work Disappointed
    Below are my lastest code:
    FLEX save_list 0.5 0 1 0
  • JuanCR
    Hi NNNNNNing
