  3. I WANTED CREATE VOID ON HOLES AS USING MY CODE ITS REMOVING...
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3046
I WANTED CREATE VOID ON HOLES AS USING MY CODE ITS REMOVING THE SHAPE DBID
Henry Monro
Henry Monro over 2 years ago
I have developed the below code and on running it is removing the Shape DBID after first void creation as shown in snap below.
I would be thankful If anyone can help in this regard and provide a better way for void creation on multiple holes.
("run"
airgap=axlFormGetField(form "airgap")
net_name=axlFormGetField(form "net_name")
void_size=axlFormGetField(form "void_size")
airgap = atoi(airgap)
net_name = upperCase(net_name)
void_size = atoi(void_size)
antipad_half=void_size/2
axlSetFindFilter(?enabled list("noall") ?onButtons list("noall"))
axlSetFindFilter(?enabled list("VIAS" "SHAPES") ?onButtons list("VIAS" "SHAPES"))
axlSelect()
l_vias_shapes = axlGetSelSet()
length_l_vias=length(l_vias_shapes)
l_shapes = list()
l_vias = list()
foreach(vias_shapes l_vias_shapes
when((vias_shapes->objType == "via" )
l_vias = append1(l_vias vias_shapes)
when((vias_shapes->objType == "shape" )
l_shapes = append1(l_shapes vias_shapes)
count=0
item_count=0
void_count=0
l_shape_void_info=nil
newshap_poly = nil
shape = nil
l_voids=nil
endType = 'ROUND
foreach(shapes,l_shapes
foreach(via,l_vias
count++
net_via=via->net->name
println("net_via")
println(net_via)
if(net_via == net_name then
list_connect=axlDBGetConnect(via t)
list_shape_layer=list()
foreach(connect list_connect
when(connect->objType=="shape" list_shape_layer=append1(list_shape_layer connect->layer))
list_shape_layer=unique(list_shape_layer)
l_airgap = axlAirGap(via shapes nil t)
object1_xy=car(cadr(l_airgap))
object2_xy=cadr(cadr(l_airgap))
airgapsize = nth(2,cadr(l_airgap))
if( member(car(l_layers_visible) list_shape_layer)== nil && airgapsize < airgap then
via_xy=via->xy
l_location=list(via_xy,antipad_half)
l_db=axlDBCreateCircle(l_location,'0,skill_layer)
circle_db=car(car(l_db))
l_poly_circle = axlPolyFromDB(circle_db ?layer skill_layer)
axlDeleteObject(circle_db)
l_poly_shape = axlPolyFromDB(shapes)
l_poly_void = (axlPolyOperation l_poly_shape l_poly_circle 'ANDNOT)
newshp = axlDBOpenShape(shapes->shapeBoundary car(l_poly_void))
foreach(poly,l_poly_void
axlDBCreateVoid(shapes,poly)
) ;; l_poly_shape_new
axlDBCreateCloseShape(newshp)
axlShapeDynamicUpdate(shapes t)
axlClearSelSet()
) ;; run
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +1 suggested
    Hi ! try this code (defun for_cut_voidshape () airgap = "5";axlFormGetField(form "airgap") net_name = "VSS"; axlFormGetField(form "net_name") void_size= "200";axlFormGetField(form "void_size") airgap…
  • SaiPavanl
    0 SaiPavanl over 2 years ago
    Hello Henrt
    I am having issue with running this code, can you provide complete code to test it at my end?
  • DE202408202727
    0 DE202408202727 over 2 years ago
    This might help:
    Note that you need to open the shape after all the other processing of the shape.
    defun( monro (airgap, net_name, void_size)
    l_layers_visible = '("ETCH/TOP")
    antipad_half=void_size/2.0
    axlSelect()
    l_vias = setof(obj, axlGetSelSet(), obj ->objType == "via" && obj ->net ->name == net_name)
    l_shapes = setof(obj, axlGetSelSet(), obj ->objType == "shape" && memv(obj ->layer, l_layers_visible))
    axlClearSelSet()
    foreach(shape, l_shapes
    l_poly_shape = axlPolyFromDB(shape)
    voidPolys = nil
    foreach(via, l_vias
    list_shape_layer = unique(setof(obj, axlDBGetConnect(via t), obj ->objType == "shape") ~>layer)
    l_airgap = axlAirGap(via, shape, shape ->layer, 'enhanced)
    airgapsize = l_airgap ->airGap || 0.0
    when(!memv(car(l_layers_visible) list_shape_layer) && airgapsize < airgap
    l_location=list(via->xy, antipad_half)
    rpath = axlPathStartCircle(l_location, 0.0)
    poly_circle = car(axlPolyFromDB(rpath))
    voidPolys = cons(poly_circle, voidPolys)
    openShape = axlDBOpenShape(shape->shapeBoundary)
    foreach(poly, voidPolys
    axlDBCreateVoid(openShape, poly)
    shape = car(axlDBCreateCloseShape(openShape))
    axlShapeDynamicUpdate(shape t)
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi !
    try this code
    antipad_half = void_size/2
    axlSetFindFilter(?enabled '(noall VIAS SHAPES NAMEFORM) ?onButtons '(noall ALL))
    axlSelect()
    l_shapes = setof(e axlGetSelSet() e->objType =="shape")
    l_vias = setof(e axlGetSelSet() e->objType =="via")
    axlClearSelSet()
    temp_list = nil
    foreach(via,l_vias
    foreach(shape, setof(e l_shapes e->net == via->net)
    tmp = shape->segments
    foreach(void shape->voids
    foreach(seg void->segments
    tmp = cons(seg tmp)
    foreach(seg tmp
    gap = axlAirGap(via seg seg->layer)
    if(gap != nil && caddr(gap) < airgap || gap == nil then
    d = axlMXYAdd( 0 : antipad_half via->xy)
    r_path = axlMakeDynamicsPath(list(list(d d 0.0 via->xy antipad_half t) list(d d) ) )
    poly = car(axlPolyFromDB(r_path ?layer shape->layer ?endCapType 'ROUND))
    if(member(poly temp_list) == nil then
    temp_list = cons(poly temp_list)
    foreach(poly temp_list
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall SHAPES NAMEFORM) ?onButtons '(noall ALL))
    axlSingleSelectBox(poly->bBox)
    shape = car(axlGetSelSet())
    HoangKhoi.
