  3. How to add APD 15.5 cns_space_values.form at 17.4
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 2687
FormerMember
FormerMember over 2 years ago
Hi Guy, How to add APD 15.5 cns_space_values.form at 17.4 ?  It will be quite convenient to set constraint by this way, thanks!/cfs-file/__key/communityserver-discussions-components-files/137/cns_5F00_space_5F00_values.zip
  • mahimag
    mahimag over 2 years ago in reply to Xiaome8 +2 suggested
    hello Xiaome8 , Allegro 17.4 and onward releases has different forms specification and rules which are for Qt based forms. There are "Tiles" defined iny our form which are not supported. Also I have noticed…
  • mahimag
    mahimag over 2 years ago +1
    Hello, do you want to load this as form or a custom menu?
  • Xiaome8
    Xiaome8 over 2 years ago in reply to mahimag +1
    Hi Mahimag, thanks for the reply. Yes, I want to set constraint through this cusom form ,actually the old allegro support this form .
  • mahimag
    0 mahimag over 2 years ago
  • Xiaome8
    0 Xiaome8 over 2 years ago in reply to mahimag
  • mahimag
    0 mahimag over 2 years ago in reply to Xiaome8
    hello Xiaome8, Allegro 17.4 and onward releases has different forms specification and rules which are for Qt based forms. There are "Tiles" defined iny our form which are not supported. Also I have noticed this,
    You can’t have a text element with NO text specified and you can’t define one text element while you’re defining another. Both are illegal syntax.
    You need to remove the tiles and correct this syntax in order to load this form.
    • Vote Up +2 Vote Down
  • Xiaome8
    Hi Mahimag,
    Thanks for your help , I  need more learning of skill and form to develop this customize feature
