  3. how to execute a skill program inside another skill ?
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 3207
Philippe LC
Philippe LC over 2 years ago
Hello
i want to execute "sauve_info.il" inside "gen_film_2024.il" for example. what is the syntax to make it ?
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago in reply to DavidJHutchins +1 suggested
    DavidJHutchins , it is only true when you use it for simple programming. I think using axlShell will be better, because the file.il case is encrypted and we only know each command. HoangKhoi.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi Philippe LC!
    You can axlShell() to call sequentially command in 2 files(.il). I really don't understand your issue.
    HoangKhoi
  • Philippe LC
    0 Philippe LC over 2 years ago in reply to Hoangkhoipcb
    Hi  @Hoangkhoi
    thanks for your answer
    so i use  *axlShell("skill _sauve_info_ext_new")"*  where :
    it ' s good
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to Philippe LC
    Hi Philippe LC!
    I wish i can help you.
    HoangKhoi.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    Philippe,
    You don't need to use axlShell(), you can call your skill routine directly using:
    _sauve_info_ext_new()
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to DavidJHutchins
    DavidJHutchins,
    HoangKhoi.
