  3. Is there a way find out if a pad is modified in the design...
  • State Suggested Answer
  • Answers 1
  • Subscribers 19
  • Views 2208
Is there a way find out if a pad is modified in the design?
HJerry
HJerry over 2 years ago
Hi all,
Is there information in a padstack that will tell if it has been modified in a design?
Jerry
  • mahimag
    mahimag over 2 years ago in reply to HJerry +1 suggested
    I don' think we have this capability yet in PCB Editor. There is a new feature in Allegro X APD , "Library Compare" which helps you compre the design data from library. https://support.cadence.com/apex…
  • mahimag
    0 mahimag over 2 years ago
    Hello Jerry,
    Yes, if you do a Show Element (Display > Element) on the pin, it will show the below message:
     "pin is EXPLODED from symbol"
  • HJerry
    0 HJerry over 2 years ago in reply to mahimag
    Only if the pad is moved will it show that it is exploded.
    I am trying to check if a padstack has been modified in the design. In particular, anti-pad size changes.
    Jerry
  • mahimag
    0 mahimag over 2 years ago in reply to HJerry
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1OPP000000P4wT2AS
    Also, there is a SKILL file available on support.cadence.com which can help you to define and extract teh "last modified date" attached to a symbol
    support.cadence.com/.../ArticleAttachmentPortal
