  3. *WARNING* (axlDBPinPairLength): Invalid database id arg...
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 20
  • Views 4932
*WARNING* (axlDBPinPairLength): Invalid database id argument
DN202408143132
DN202408143132 over 2 years ago
I'm trying to run the axlDBPinPairLength, but I can't get correct arguments. I've tried axlDBPinPairLength("U44.AB26" "U103.P3") and axlDBPinPairLength(U44.AB26 U103.P3) which gives Invalid database id argument and nil, respectively. Does anyone know what I'm doing wrong?
  • DN202408143132
    0 DN202408143132 over 2 years ago in reply to DE202408202727
    Thanks for the prompt replies. It is working. I will look into Lisp more so I have a better understanding. I have the pin names from reports I have generated. I can also get the dbid of these pins from something like axlSelectByName("PIN" "U96.P3"). I guess I am not sure how this dbids work if I can't put them in as an argument. Do you have any information on these or reference documents?
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to DN202408143132
    I'm glad you are on the right track.
    There are good learning materials on the support site.
    "Allegro X User Guide: SKILL Reference" is invaluable
  • mahimag
    0 mahimag over 2 years ago in reply to DE202408202727
    adding some links from support.cadence.com which can help with SKILL
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=algroskill.xml&title=Allegro%20X%20User%20Guide:%20SKILL%20Reference%20--%20Skill%20Language%20Extensions%20-%20lastelem&hash=pgfId-1067560&c_version=23.1&path=algroskill/algroskill23.1/27langexten.html#pgfId-1067560
    Allegro PCB Editor SKILL Code Library:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000051TEEAY
