  3. *WARNING* (axlDBPinPairLength): Invalid database id arg...
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 20
  • Views 4931
*WARNING* (axlDBPinPairLength): Invalid database id argument
DN202408143132
DN202408143132 over 2 years ago
I'm trying to run the axlDBPinPairLength, but I can't get correct arguments. I've tried axlDBPinPairLength("U44.AB26" "U103.P3") and axlDBPinPairLength(U44.AB26 U103.P3) which gives Invalid database id argument and nil, respectively. Does anyone know what I'm doing wrong?
  • DE202408202727
    0 DE202408202727 over 2 years ago
    axlDBPinPairLength takes pin dbids as arguments not pin names.
  • DN202408143132
    0 DN202408143132 over 2 years ago in reply to DE202408202727
    Hi Dave,
    I also tried to use dbids with no success. I grabbed some pins using "net = car(axlSelectByName("NET" "PROC_EXAMPLE"))" and then lpins = axlPinsOfNet(net, 'pins). I then tried some methods of pasting the dbids:
    axlDBPinPairLength(dbid:000001A43FE50BB0 dbid:000001A44044AB08)
    axlDBPinPairLength("dbid:000001A43FE50BB0" "dbid:000001A44044AB08")
    axlDBPinPairLength(000001A43FE50BB0 000001A44044AB08)
    axlDBPinPairLength("000001A43FE50BB0" "000001A44044AB08")
    Maybe I am inputting the arguments incorrectly? I just started using SKILL today, so apologies for my ignorance here. I am trying to eventually make a custom report to get etch lengths between pin pairs of my own choosing, similar to the "Etch Length by Pin Pair" report.
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to DN202408143132
    You can't type in the dbids. Try something like axlDBPinPairLength(car(lpins), cadr(Ipins))
  • DN202408143132
    That worked (assuming cadr is a typo and should be car). My question now is that how would one go about and specify a pin if the net has multiple pins? Is there also a way to convert dbids into something that axlDBPinPairLength would take as an argument?
  • DE202408202727
    cadr isn't a typo. It returns the second item in a list.
    To get the correct pin requires an understanding of Skill that you will need to develop.
    dbids are dynamic so  you should never "convert" them.
