  3. Compare Structures using skill
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 2583
Hussain Aalim
Hussain Aalim over 2 years ago
I wanted to compare the structures using a reference structure It would be nice if someone can help in this regard.
Below are the structures:
I wanted to automate it as there are many structures and wanted to know if any object is missing or extra.
  • mahimag
    mahimag over 2 years ago in reply to Hussain Aalim +1 suggested
    There are some SKILL APIs for modules, like axlDBCreateModuleDef, axlDBCreateModuleInstance which you can check You can check the syntax from teh below link: https://support.cadence.com/apex/techpubDocViewerPage…
  • mahimag
    0 mahimag over 2 years ago
    not sure about SKILL but are these structures created as Modules? If yes, you can use Place Replicate Apply and apply the base module to all the structures, if there is a difference you get "Place Replicate Component Swap Interface Dialog Box" which can give idea.
  • Hussain Aalim
    0 Hussain Aalim over 2 years ago in reply to mahimag
    Can you please let me know how I can implement Place Replicate Apply using Skill?
  • mahimag
    0 mahimag over 2 years ago in reply to Hussain Aalim
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=algroskill.xml&title=Allegro%20X%20User%20Guide:%20SKILL%20Reference%20--%20Logic%20Access%20Functions%20-%20axlDBCreateModuleDef&hash=pgfId-1075174&c_version=23.1&path=algroskill/algroskill23.1/26logacc.html#pgfId-1075174
