  3. Adding skill command to the toolbar incl. Icon
  • Replies 11
  • Subscribers 24
  • Views 6983
PatEscher
PatEscher over 2 years ago
does anyone know if it is possible to add a skill command I created/registered to the toolbar and also assign an icon to it programmatically via skill?
No problem to add the skill commands as a menu (like the File menu for example)
No problem in manually adding the skill comman to the toolbar by going through View --> customize toolbar
But as said, I want to do it programmatically, as otherwise all our users have to do by themselves
Patrick
  • JuanCR
    JuanCR over 2 years ago +1
    Hi Patrick I see you know the method through "View > Customize toolbar". Are you instead looking for a SKILL command that would add a menu or toolbar? Have you seen the follwoing article: Article…
  • JuanCR
    0 JuanCR over 2 years ago
    Hi Patrick
    Article (20416434) Title: Adding and Appending Allegro Menu Items using SKILL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050ObEAI
    I'm attaching the PDF in case you don't have access to our COS website.
    Adding_Appending_ AllegroMenuItems_SKILL.pdf
  • PatEscher
    0 PatEscher over 2 years ago in reply to JuanCR
    Hello Juan,
    no, how to add a new menu like described in the pdf is not a problem. we are already doing this. --> this is going into the menu bar
    We want to add it into the tool bar, like when doing it through the View > Customize Toolbar
  • HLBhuvan
    0 HLBhuvan over 1 year ago in reply to PatEscher
    Hello Pat,
    Kindly refer the picture how to add the tool bar and customise.
    HLB
  • PatEscher
    0 PatEscher over 1 year ago in reply to HLBhuvan
    Hello HLB,
    I need a way to do this programmatically. Doing it through the UI it not an issue but is not what we need.
    Patrick
  • Mhawley1
    0 Mhawley1 over 1 year ago in reply to PatEscher
    I am in the same boat. Say I have 100 Users of allegro and I need to add a Icon on all of their machines. I need a programmatic way to do this just like adding skill Menu's .
    The only thing I can think of is recording a script that does it and forcing that to run right at bootup of the Allegro Instance . But thats hacky and error prone . Maybe this can be a feature added in the 25 release.
