  3. Adding skill command to the toolbar incl. Icon
  • Replies 11
  • Subscribers 24
  • Views 6990
PatEscher
PatEscher over 2 years ago
does anyone know if it is possible to add a skill command I created/registered to the toolbar and also assign an icon to it programmatically via skill?
No problem to add the skill commands as a menu (like the File menu for example)
No problem in manually adding the skill comman to the toolbar by going through View --> customize toolbar
But as said, I want to do it programmatically, as otherwise all our users have to do by themselves
Patrick
  • JuanCR
    JuanCR over 2 years ago +1
    Hi Patrick I see you know the method through "View > Customize toolbar". Are you instead looking for a SKILL command that would add a menu or toolbar? Have you seen the follwoing article: Article…
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago in reply to PatEscher
    p.s. You can still save/export these settings in the UI settings manager, but the're saved in binary and I don't know how to handle this without the aid of scripting. Moreover, they will override the individual UI setup, which is bad.
