  3. How to add a user-defined subclass
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 20
  • Views 6017
EdwinB
EdwinB over 2 years ago
Is there a way to add a user-defined subclass to the Define Subclass dialog box using Skill?
For example:
I want to add "MY_SUBCLASS" to the "BOARD GEOMETRY" class. If so, how do you go about it?
I am doing this to reduce the time spent manually adding the subclasses in the Define Subclass dialog box. I have about 50+ subclasses to add to different the Classes.
Thank you,
Eddie
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to EdwinB
    Eddie,
    Hopefully this will help you with your issue...
    I just wrote the following skill code that will output the custom subclass definitions to a script file so you can replicate them in another design:
    procedure(export_subclasses()
    let((scriptFile layCnt subclass)
    (scrFile = axlDMOpenFile("ALLEGRO_SCRIPT" "subClasses" "w"))
    (layCnt = 0)
    foreach(Class axlClasses()
    foreach(Subclass axlSubclasses(Class ?field 'userDefined)
    (subclass = sprintf(nil "%s/%s" Class Subclass))
    unless(axlIsEtchLayer(subclass)
    fprintf(scrFile "skill (axlLayerCreateNonConductor \"%s/%s\")\n" Class Subclass)
    layCnt++
    axlDMClose(scrFile)
    axlMsgPut("%d subclass definitions written to %s" layCnt scrFile)
    axlCmdRegister( "export_subclasses" 'export_subclasses ?cmdType "general")
  • EdwinB
    0 EdwinB over 2 years ago in reply to DavidJHutchins
    Hi Dave,
    Thank you very much for this code. I'll give it a try and let you know the results.
  • EdwinB
    0 EdwinB over 2 years ago in reply to EdwinB
    Hi Dave,
    Just finished running the skill/script and it works great.
    Many thanks again!
    EdwinB
