  3. How to add a user-defined subclass
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 20
  • Views 6016
EdwinB
EdwinB over 2 years ago
Is there a way to add a user-defined subclass to the Define Subclass dialog box using Skill?
For example:
I want to add "MY_SUBCLASS" to the "BOARD GEOMETRY" class. If so, how do you go about it?
I am doing this to reduce the time spent manually adding the subclasses in the Define Subclass dialog box. I have about 50+ subclasses to add to different the Classes.
Thank you,
Eddie
  • DE202408202727
    0 DE202408202727 over 2 years ago
    Yes. Try axlLayerCreateNonConductor("BOARD GEOMETRY/MY_SUBCLASS")
  • EdwinB
    0 EdwinB over 2 years ago in reply to DE202408202727
    Hi Dave,
    Thank you for the feedback. I'll give it a try and let you know if it works.
    EddieB
  • EdwinB
    0 EdwinB over 2 years ago in reply to EdwinB
    Hi Dave,
    I'm not sure if I'm doing this correctly but it's giving me an error code:
    "*Error* axlLayerCreateNonConductor: argument #1 should be a string (type template = "t") - nil"
    Here's the skill I'm using:
    procedure(runMexx()
    l_vis=axlVisibleGet()
    brd_layer = axlSubclasses("BOARD GEOMETRY" ?field 'userDefined)
    if((brd_layer != nil)
    foreach(subclass brd_layer
    axlClearSelSet()
    temp_Layer = sprintf(nil "BOARD GEOMETRY/%s" subclass)
    axlVisibleDesign(nil)
    axlVisibleLayer(temp_Layer t)
    axlVisibleUpdate(t)
    axlSetFindFilter(?enabled '(noall lines shapes figures text) ?onButtons '(noall lines shapes figures text))
    axlAddSelectAll()
    lyr_data = axlGetSelSet()
    axlClearSelSet()
    axlLayerCreateNonConductor(lyr_data)
    my_subclass = axlLayerGet(temp_Layer)
    axlLayerCreateNonConductor(my_subclass)
    ); foreach
    ) ;if
    axlVisibleSet(l_vis)
    axlVisibleUpdate(t)
    ); end procedure
    Ty.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to EdwinB
    I think there are a couple of errors in your code, 1st issue is the following:
    axlClearSelSet()
    You are getting the error since lyr_data is an empty list & the function wants a string value
    The 2nd issue is in the following code:
    This will not work since my_subclass is just the subclass name & the function wants a string value containing the class & subclass values, below is from the doc:
    NEEDS
    t_layerName - <class>/<subclass>
  • EdwinB
    0 EdwinB over 2 years ago in reply to DavidJHutchins
    Hi Dave,
    Thank you for the feedback. This is an existing code, I thought I could use it. I guess not.
