  3. gerber (and other manufacturing) export via SKILL?
  • State Verified Answer
  • Subscribers 21
  • Views 3817
drdanmc
drdanmc over 2 years ago
Are there some SKILL functions for generating manufacturing files such as RS247X, NC Drill, and also things like STEP export, PDF export, etc?  Or do these things need to be done via individual command line programs like `artwork`?
My goal is to automate as much as possible to make it possible for anyone on the team to be able to generate these files without needing to navigate several different menus and be presented with many different options that will get in the way of consistency across a team.  I don't have much Allegro experience but have extensive experience with Virtuoso, SKILL in Virtuoso, and the IC flow in general.  I've always used automation for chip tapeout so anyone on our team can confidently generate all output with a simple command.
-Dan
  • DavidJHutchins
    DavidJHutchins over 2 years ago +2 verified
    Most of the manufacturing outputs are individual programs sub-invoked from within Allegro using axlRunBatchDBProgram(), look in <installdir>/share/pcb/batchhelp/ for info on 'artwork', 'nctape', 'ncroute…
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago
    look in <installdir>/share/pcb/batchhelp/ for info on 'artwork', 'nctape', 'ncroute' and the various '*_out' commands...
    I used most of these when I developed an automated export routine for Intel 20 years ago...
    • Vote Up +2 Vote Down
  • drdanmc
    0 drdanmc over 2 years ago in reply to DavidJHutchins
    Thanks.  That's a big help.  I find sometimes 75% of the battle is getting to the right place in the documentation.
